  • August 02, 2025, 03:40:32 AM
Author Topic: WTB Tamigo Trainer / plans or kit.  (Read 952 times)
Offline Lyle Spiegel
« on: May 03, 2023, 06:50:15 PM »
WTB Mike Hoyt amigo Trainer / plans or kit.
Lyle Spiegel AMA 19775
Re: WTB Tamigo Trainer / plans or kit.
« Reply #1 on: May 03, 2023, 08:42:13 PM »
I checked the AMA plans site and they don't show it.  Was this a magazine plan? D>K
Offline Carl Cisneros
« Reply #2 on: May 07, 2023, 12:15:28 PM »
IF memory serves, the Tamigo was only availabe as a kit from Mike.
If you do happen upon a kit, when building it, raise the tail pipe aprox. 3/32" HIGHER than the metering jet center line.
This is where we found the plane tracks nice and level with out much at all control input.
That is the jet I learned on back in '74.
with tied lines (made illeagle after that summer, or was it '74?), I got mine up into the low 170's. Normal speed is around 140 plus depending on fuel/air/model set up.
(if flying with 2 lines)
Then I went on to the Sidewinder and then Ironsides.
Carl Cisneros
Carl R Cisneros, Dist IV
Control Line RB
Offline Dave Rigotti
« Reply #3 on: May 07, 2023, 12:31:30 PM »
Do you want this for simply sport flying?
Here's a MUCH better choice for a Dyna-Jet powered plane. It's "almost" an ARF.  Will do 135-140MPH.
https://pylon-line.myshopify.com/collections/control-line-parts/products/robert-bolton-t34-sport-jet-kit.  While your at it...get the 12 hole flowjector and ditch the DJ one.
Dave Rigotti
AMA 66859
Chesterland, Ohio
