  • August 02, 2025, 04:28:29 AM
Author Topic: McCoy 40 R/H thunder bolt  (Read 1239 times)
Offline Bootlegger
« on: December 30, 2021, 01:15:01 PM »
would a thunder bolt Red head 40 take a piston and liner from a series 21 40 block and make a ringed stunt 40 ? all help will be appreciated,,, Much  obliged   n~ :! #^ y1
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Manuel Cortes
Re: McCoy 40 R/H thunder bolt
« Reply #1 on: December 30, 2021, 09:49:14 PM »
Hi Gil.
I think so, as I bought several years ago a called "hybrid McCoy 40" who has exactly that mod performed. What I don´t Know is if it is necessary some machining work to adapt the pieces.
Kind regards from Spain.
Manuel.
« Reply #2 on: December 31, 2021, 09:07:24 AM »
Gil it can be done but requires the case to be bored out several thousandths to fit the Series 21 sleeve.  I attempted to do one recently by simply hogging it out with a grinding stone.  I got the engine together but couldn’t get it to start by hand.  I may take the electric starter next time I try.  I think once it gets loosed up....
Offline De Hill
« Reply #3 on: December 31, 2021, 06:18:03 PM »
It can also be done by taking the cylinder of a lightning bolt Mccoy .40 and using the rod and piston out of a series 21 Mccoy .40. Stick that assembly back into a lightning bolt Mccoy .40 crankshaft and crankcase.
Then you will have what you want.
De Hill
