  • August 01, 2025, 07:33:02 PM
Author Topic: Blank  (Read 2296 times)
Offline Rusty
Blank
« on: May 16, 2020, 06:23:37 PM »
Blank
« Last Edit: March 10, 2022, 10:59:55 PM by Air Master »
Offline Robert Whitley
Re: Want To Buy: Fox 35 / 36 Combat Venturi Insert
« Reply #1 on: May 16, 2020, 09:24:55 PM »
Check with Jim Lee.
He has them listed in his catalogue, cheap too.
Offline Fredvon4
  • Central Texas
« Reply #2 on: May 17, 2020, 07:39:31 AM »
I believe the Fox combat suction venturi INSERT is square reducer
I think I have one from a trashed Fox36 MKIV
PM an address and it is yours
Fred von Gortler IV
Offline kenneth cook
« Reply #3 on: May 17, 2020, 08:01:51 AM »
             Fred, the 35/36 combat engines were the X series. The MK series inserts don't fit those engines. I make mine from maple motor mount stock which is very simple to do. I sand some taper on them and friction fit them to the venturi and mark and drill for the spraybar.
Offline Gordon Van Tighem
« Reply #4 on: May 20, 2020, 12:39:53 AM »
If it’s a Rocket, isn’t the Venturi round?
The X and MK are square..
G
Gord VT
MAAC 3738L, Life Member
AMA C3738L
« Reply #5 on: May 20, 2020, 01:01:42 PM »
             There was a square venturi Rocket case combat engine which had a needle bearing 4 bolt front end. I believe it's also referred to as the "61" special due to the year it was introduced.
« Reply #6 on: May 20, 2020, 07:09:41 PM »
               That's the engine, I have two of them and I enjoy using them. Make certain that the backplate isn't drilled for crank pressure if your going to use it on suction.
« Reply #7 on: May 22, 2020, 03:35:03 PM »
Easy fix.
Just screw in an appropriately threaded plug.
