  • August 01, 2025, 07:30:43 PM
Author Topic: Fox 19 & 25  (Read 1580 times)
Offline Bootlegger
Fox 19 & 25
« on: March 23, 2021, 08:19:48 AM »
  Need to find a needle and spray bar that I can replace the stock needle and spray bar in these engines with a needle assy with a single hole spray bar ...   Obliged    D>K    H^^
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Fox 19 & 25
« Reply #1 on: March 24, 2021, 04:33:19 PM »
Contact Randy Smith - his PA NVA for Fox should work really good.
Best,   DennisT
Offline Bootlegger
Re: Fox 19 & 25
« Reply #2 on: March 25, 2021, 10:37:50 AM »
 Thanks Dennis, talked to R Smith and was told he has nuttin to fit, so I checked the dia and it is .093, will continue to search.. y1
Gil Causey
AMA# 6964
Re: Fox 19 & 25
« Reply #3 on: March 25, 2021, 11:05:17 AM »
Did you try MECOA?  I just ordered some venturis for the FOX .15 and they are on the way.  By The way the NV assemblies I got from Randy Smith were a little tight so I reamed out the hole for the spray bar.  Engines start and run great.  Did have to ream some washers ti center the spray bar hole. D>K
