General control line discussion => Classifieds => Topic started by: Bootlegger on March 23, 2021, 08:19:48 AM
Need to find a needle and spray bar that I can replace the stock needle and spray bar in these engines with a needle assy with a single hole spray bar ... Obliged D>K H^^
Contact Randy Smith - his PA NVA for Fox should work really good.
Best, DennisT
Thanks Dennis, talked to R Smith and was told he has nuttin to fit, so I checked the dia and it is .093, will continue to search.. y1
Did you try MECOA? I just ordered some venturis for the FOX .15 and they are on the way. By The way the NV assemblies I got from Randy Smith were a little tight so I reamed out the hole for the spray bar. Engines start and run great. Did have to ream some washers ti center the spray bar hole. D>K
