  • June 16, 2025, 06:18:55 AM
Author Topic: 3 Used Fox Engines A .15, .35, and a .36*******SOLD*******  (Read 1236 times)
Offline Crist Rigotti
« on: September 11, 2022, 06:24:01 PM »
3 used Fox engines.  A .15, a 40th anniversary .35, and a .36.  What you see is what you get.  $40 shipped to the lower 48.
« Last Edit: September 12, 2022, 07:23:24 AM by Crist Rigotti »
Offline bill bischoff
Re: 3 Used Fox Engines A .15, .35, and a .40
« Reply #1 on: September 11, 2022, 07:33:29 PM »
What you're calling a 40 probably isn't. I only remember that engine being available as a .29 or a .36. I had one of the .36's long ago. It was noticeably more powerful than the .35 stunt.
BB
« Reply #2 on: September 11, 2022, 08:08:26 PM »
BB
    Yeah, I think it's a slant plug .29 or .36 also. Only way I could tell is to take the head off and measure the bore. Sceptre Flite web site has the specs for those engines. The .40 Stunt has a muich different case, especially on the bypass side.
Online afml
« Reply #3 on: September 11, 2022, 09:30:12 PM »
Well........
The way I determine if the motor in question is a 29 or 36 is to look on the top of the mounting lug.
The 29 is stamped '29', the 36 has no stamping.
Good luck & "Tight Lines!" H^^
Wes
Wes Eakin
« Reply #4 on: September 11, 2022, 09:59:13 PM »
OK guys.  We'll call it a .36 then.
Online Dave Rigotti
Re: 3 Used Fox Engines A .15, .35, and a .36
« Reply #5 on: September 12, 2022, 01:46:32 AM »
I'll take em......
Dave Rigotti
AMA 66859
Chesterland, Ohio
« Reply #6 on: September 12, 2022, 07:19:06 AM »
Well........
Wes
   That's too easy! You don't need tools or anything to do that!! LL~ LL~  I had forgotten about that detail. I'm pretty sure I have examples of each.
« Reply #7 on: September 12, 2022, 07:22:57 AM »
Re: 3 Used Fox Engines A .15, .35, and a .36*******SOLD*******
« Reply #8 on: September 12, 2022, 07:37:00 PM »
Does that mean they were already his, or just that they are his now? n~
« Reply #9 on: September 13, 2022, 05:18:15 AM »
The later!
