  • August 01, 2025, 04:13:39 AM
Author Topic: Goldberg Shoestring  (Read 6427 times)
Offline David Ruff
Goldberg Shoestring
« on: March 08, 2018, 03:39:29 AM »
Well I got this far.  She weighs about 18 oz right now.  My calculations put her at about 32 oz final weight.  That translates to a wing loading of about 11.5 oz per sq ft.  At the limit and approaching PIG status.
But it is what it is.
Power is Fox .29 Stunt.
Five coats on the wing.  I will be using one coat of primer and red dope on the fuselage and tail.
Hope it flys.
Retired Army
Offline David Ruff
Re: Goldberg Shoestring
« Reply #1 on: March 09, 2018, 05:18:53 AM »
Thanks, Ty.  I should try one of the club's.  I prefer not crashing my own.
I just applied first coat of primer and I am thinking of keeping it one color to keep weight down.
It will probably come out to about 32 oz finished.  I cannot get any heavier than that.
The old kits were heavy.
Retired Army
Offline Terrence Durrill
« Reply #2 on: March 09, 2018, 10:10:23 AM »
                                        Yes the old kits could be heavy, but I found over the years, that they flew pretty darn good...........especially for the primarily sport flier like myself.  ............  Most of them still flew better than I did.       D>K       H^^
Offline David Ruff
« Reply #3 on: March 09, 2018, 10:51:23 AM »
Oh it will fly better than I can.  This will probably be crashed pretty quickly.  Learning causes crashes.
Retired Army
  • Gravitywell
« Reply #4 on: March 09, 2018, 11:57:05 AM »
Or is it crashes cause learning? %^@ H^^  One of my first "real" control line planes was a Shoestring.  I have very fond memories of her and how well she flew.  I have no idea how many times I crashed then rebuilt her, but she did what was needed and got me onto my next big plane.....a Midwest Skyraider.
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline TigreST
  • TigreST
« Reply #5 on: March 09, 2018, 06:47:17 PM »
First and only Goldberg Shoestring I built was Fox .35 powered (no muffer) and had alum. landing gear legs. (there's another one in the stash) No idea what the weight was. As already stated, "It flew better than I could fly it."  First plane I went inverted with.  One of my all time favorite combo's..the Shoe and Fox 35.  Although weight control while building is something to consider it's not the only thing when your just getting your wings.  Your in for a great time me thinks.
T.
« Last Edit: March 21, 2018, 04:02:41 AM by TigreST »
Tony Bagley
Ontario, Canada
Online gene poremba
« Reply #6 on: March 11, 2018, 01:47:32 PM »
 Dave, my Shoestring flies just fine at 33oz with a Mcoy .35. It was also my first build after a long lay off at C/L. I had to add nose weight to mine to get it to balance. I hope you enjoy your Shoestring as I have with mine......Gene
Offline Geoff Goodworth
« Reply #7 on: March 13, 2018, 06:52:47 PM »
That's interesting, Gene.
All mine—prototypes of the Brodak version—have weighed 29 oz and required 1/4–1/2 oz of lead under the tail—with an FP 20 for power.
« Reply #8 on: March 13, 2018, 11:16:42 PM »
Here in straylia the ' Bendix ' T/R Regs were writen round the Goldberg Shoestring Dimensions . 60 ft lines , 0.36 cu.in. injun .
You can see it has a hoary great Nelson .36 or somesuch . The Olde Oak in some Goldberg Kits lets em stand up to a bit or rough & tumble .
Not to mention the solid L E & TE , .
More pitchers .the White Things a Nemisis , I think . Not Aerobatic at that speed . Goldberg Drg. Below .
Id dome one with a FSR Magnum 25 pro , centuies back , Silk & Tissue over .no stickers .mightvebeen 36 Oz.
« Reply #9 on: March 14, 2018, 07:41:56 PM »
The Goldberg Shoestring was one of the best flying simple profiles, and still is.  Some were lighter, but 28-32 oz. were typical weights.
I think I still have the first one I built 'cause it never had a serious crash.  Not bad for learning how to at least try, if not fly, all the maneuvers.
Offline Doug Burright
  • Legacy, Brodak kit
« Reply #10 on: March 19, 2018, 10:25:04 PM »
A friend and I refurbished this Goldberg Shoestring during the winter. We found a roll of iron-on blue Coverite, and red Ultracote iron-on, cut specifically for this refurbishing job. Weight is not an issue, because we don't intend to compete with it in any manner. Pieces of the blue Coverite were sewn together to make the hinge for the elevator and stabilizer. It was a fun project to work on during the dark days of winter!
« Last Edit: March 19, 2018, 10:46:20 PM by Doug Burright »
I will build it. It's gonna be really difficult to find me with an ARF. I know every bit of my airplane!
Offline David Ruff
« Reply #11 on: March 22, 2018, 09:31:49 AM »
It came out to 32 oz and flies very well.
Retired Army
Offline David Ruff
« Reply #12 on: March 25, 2018, 04:31:16 PM »
Second flight (fright).  Engine too rich, very windy, my second flight in about two years and I am a beginner.  Lines going slack, I backpedaled to save.  Almost bought the farm as you can see.
Ty told me it was good training.
Third flight here was a better engine run.
I think I was lucky that I did not cream it today.
Seriously.  We are talking almost seven second laps.  I had to whip it around.
Retired Army
« Reply #13 on: March 25, 2018, 07:16:39 PM »
At least it is flying.   Remember the hardest maneuvers to learn/teach is take off, level flight and landing.  Once you find the needle setting and prop the plane likes you will start having even more fun. H^^
Offline Skip Chernoff
« Reply #14 on: March 26, 2018, 07:25:04 AM »
Here's a pic of my just finished Shoestring......PhillySkip
Offline David Ruff
« Reply #15 on: March 27, 2018, 07:34:08 AM »
found the vid of the first flight.  probably the best.
Retired Army
