  • June 18, 2025, 01:16:22 AM
Author Topic: Will a LA .46 be  (Read 2591 times)
Offline Jim Pollock
Will a LA .46 be
« on: January 21, 2010, 09:21:58 PM »
I didn't want to put the entire question in the Subject line so here goes....
Will the LA .46 be enough power for a 56" Span 50 ounce thereabouts Gypsy???  I think so, but would like all other opinions as well??
Jim Pollock....... ???
Re: Will a LA .46 be
« Reply #1 on: January 22, 2010, 12:58:40 AM »
  Plenty.
« Reply #2 on: January 22, 2010, 10:41:48 AM »
Pat Johnston was using one in a Shark 35 (pretty big, comparatively heavy plane). It would very, very well.
« Reply #3 on: January 22, 2010, 10:16:15 PM »
Yep., LA 46 would be a great engine for that, perfect size,,
I know my LA 46s ahve pulled lots of weight,, nope aint gonna say, but its at least 8 oz more than your projected weight, on a 570 inch wing, and didnt squack at all,, it was great then too,,
Offline Mike Scholtes
« Reply #4 on: January 23, 2010, 01:12:43 PM »
I powered a 630" Imitation with a basically stock LA46, modied only with Randy Smith NVA and tube muffler. This is a fairly thick wing that requires good power. No problem at all. It really likes the APC 12.25 x 3.75.
Offline Greg L Bahrman
« Reply #5 on: January 24, 2010, 10:24:50 PM »
My profile Cardinal is 50 oz. and the L.A. 46 goes vertical with authority anytime I request it.........Also using the APC 12 1/4 x 3 3/4 prop.
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline Jim Pollock
« Reply #6 on: January 25, 2010, 08:49:11 PM »
Ty,
Aren't the mounting holes quite a bit different between the OS LA .46 and the ST G21 .51?
Jim Pollock  H^^
Offline Jim Pollock
« Reply #7 on: January 29, 2010, 09:01:09 PM »
Ty,
Yes, I have cut a set of ribs for the larger Gypsy but that's as far as I have gotten so far.  I'm going to build up the Stab and Elevators to lighten the rear load some so the LA .46 will balance it pretty well.  Next is to extend some 36" 1/8 inch balsa to 37" to make the slightly longer than standard fuselage.  I've also dreamed up fuselage doublers out of 3/32" balsa laminated to 1/32" ply with carbon fiber in between.  My buddy Mike Thompson built one in '73.  That one weighed 48 ounces and was powered with a GMA modified OS .40H-S.  I'm going to duplicate that plane except for the engine.
Jim Pollock   H^^
Offline Jim Pollock
« Reply #8 on: January 31, 2010, 09:34:33 PM »
The OS .40H-S flew the Gypsy very well.  As I can remember about a 5.2 lap time on 63 foot lines and plenty of line tension all around.  I did fly it a few times before he left for the '73 Nats with it.
Jim Pollock   H^^
