  • June 16, 2025, 10:08:57 AM
Author Topic: Cobra Kit  (Read 1195 times)
Offline Bryan Higgins
Cobra Kit
« on: February 02, 2009, 05:33:30 PM »
Hello Flyers
Is there anyone out there still producing a Steve Wooley Cobra Kit.??? %^@
I would like to build my Father one. Don't Really know if im ready to build
one from plans yet.
                                                             Thanks: Bryan ???
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
Offline steve pagano
Re: Cobra Kit
« Reply #1 on: February 02, 2009, 06:46:07 PM »
     It's on Pat Johnstons plans list, He can laser cut you a short kit.
                       Steve P.
Success isn't a destination.It's a journey!!!!!
A.M.A. 820-823
Re: Cobra Kit
« Reply #2 on: February 03, 2009, 12:55:21 PM »
Not sure if Brodak is still doing a short kit. Pat would probably be the best option.
Re: Cobra Kit
« Reply #3 on: February 04, 2009, 10:22:31 AM »
It is so easy to build from plans and it only needs $15 worth of wood. You do not need contest wood for the strip ribs just good quality medium weight wood. Every rib is cut the same and shortened as you need it so they always fit perfect.I laminate the thick ribs next to the body instead of using 1/2" balsa.Same thing with the wing tips.Very easy and light.Stab is sheet and needs to be light unless you are using a heavy motor. Use cloth hinges.
Re: Cobra Kit
« Reply #4 on: February 04, 2009, 10:05:59 PM »
Thanks Guys
I found the Kit and Plans at Pat's site $51.00 for the ribs and set of plans.
The plans are nice. full size
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
