  • June 16, 2025, 08:17:23 AM
Author Topic: Caprice  (Read 6663 times)
Offline James Mills
Caprice
« on: September 09, 2011, 10:10:43 PM »
I know Bob and many of the others who have built a Caprice use the Aero 36.  Would a Magnum 36 for power work?
James
AMA 491167
Re: Caprice
« Reply #1 on: September 09, 2011, 11:14:20 PM »
Hi James,
The Magnum .36XLS (square head) will work fine.  Remember it does have a bit different "run" from the AT .36.
Offline peabody
Re: Caprice
« Reply #2 on: September 10, 2011, 06:42:25 AM »
Yes
Offline James Mills
Re: Caprice
« Reply #3 on: September 10, 2011, 12:31:22 PM »
Yes
Peabody whick way are you voting, on Stuka you said "no".
James
AMA 491167
Re: Caprice
« Reply #4 on: September 10, 2011, 04:07:13 PM »
You expected logic? From Peabody? Really?  LL~ Steve
Re: Caprice
« Reply #5 on: September 11, 2011, 07:51:50 AM »
I promised not to say anything about Mr. P.   But, why not go electric like Bobby has? H^^
Offline peabody
Re: Caprice
« Reply #6 on: September 11, 2011, 08:16:25 AM »
James...
A definition of insanity that I frequently use is doing the same thing over and over and expecting different results......
Since you asked the same question on both boards almost simultaneously, I assumed that you were looking for different results....
Re: Caprice
« Reply #7 on: September 11, 2011, 11:45:37 AM »
Wow, Peabody misquoting Einstein.
Offline James Mills
Re: Caprice
« Reply #8 on: September 11, 2011, 12:38:25 PM »
James...
That's a silly assumption.  I posted on both sites because I don't assume everyone visits both sites.
James
AMA 491167
Offline James Mills
Re: Caprice
« Reply #9 on: September 11, 2011, 12:39:40 PM »
John,
I am planning to go electric, just wasn't planning to do it with a classic bird.
James
AMA 491167
Re: Caprice
« Reply #10 on: September 12, 2011, 01:04:46 PM »
John,
James
Hi James,
Not trying to "start"anything, and Mr. Hunt might have changed is mind since we talked about it, but he said he still liked to use an IC engine in his "Classic" models.
I'm sure he will comment if I am wrong. ;D
As to the Magnum, we have used it and found it is a fine stunt engine "out of the box" run with PTG's set up, but it ain't an Aero Tiger .36.  However, it did power Aaron's Ares that he used to win his class in Classic at Brodak's a few years ago. ;D
Re: Caprice
« Reply #11 on: October 09, 2011, 11:05:26 PM »
Bill is not wrong; I will not use electric power inClassic or OTS. This is a personal decision and I really don't care if others choose to use electric power for their models in those events. I just don't feel that it is in the spirit of the events for me. True, modern Schneurle engines are probably not either, but it is getting difficult to find useable, reliable older engines for those craft. If a rule was passed stipulating that we had to use period accurate engines, I suppose I'd go shopping for one...
Later - Bob Hunt
Hmmm.  OK Bubba,
Can I go one step further.  Was just fooling around with my old Chizler and pulled a new .25VF out of the closet with a header attached, looked at that fat belly and got to thinking what would Uncle Mikey say if I showed up in Tucson with a Chizler with a tiny little .25 in it.  Shucks, its just a fancy muffler and every one is using mufflers in the Classic ships along with their Aero Tigers.
The Chizler has to be repainted and recovered anyway (like all of my old colored paper classic ships, the plyspan has split in numerous places) and I was thinking about dropping an ST .46 in it for desert flying purposes.  Alas, the nose isn't wide enough and I don't want to carve up any of the STs to squeeze them in...plus they weighs a lot more than the Big Art .35 which already made the thing nose heavy with the muffler on it.  The little VF just seems "right" somehow.
Are we talking the infamous slippery slope here?
Ted
Re: Caprice
« Reply #12 on: October 09, 2011, 11:35:04 PM »
Well, Brother Ted,
You Can use one of Randy's can mufflers hung off the end of the header, maybe even get one in CF!
I am still planning on doing the surgery on the '59 Ares to see how the .25VF WITH a pipe does in it.  But if it turns out as well as I expect, and it should, I would only enter it in PAMPA class. S?P
Re: Caprice
« Reply #13 on: October 10, 2011, 09:21:35 AM »
Ted,
Well, you could use the VF25 with a 1/4 wave "muffler". Or you could stick a PA 40UL in there. They only weigh a touch over 8oz.
Re: Caprice
« Reply #14 on: October 10, 2011, 09:47:32 AM »
Ted,
Bill and Randy,
Oooops.  Just reread my post and see that I forgot to mention my intention is to use a pipe.  It's something I've wanted to try for many years and when the covering started popping on the Chizler I just thought this might be the impetus I need to try it out.
Back in the WAM "A" stunt days we did some pretty amazing things with VECO .19BBs.  David's dad had a beautiful Dolphin with one that flew brilliantly and another flying buddy had a Gieseke Nobler with one that was very competitive...plus a lot of Banshees, etc. that seemed to fly better with the .19s than they did with the "standard" Fox and Max .35s.  If the little .25 can boost that performance five or 10 percent with its greater raw power plus a pipe I think the result could be awesome.
By the way, we flew those airplanes almost exclusively with Rev Up 10X4s cut to a satisfying length and spinning at somewhere between 10 to 11K (although we didn't use tachs in those day).  Sounds strangely like what we do nowadays with our .40s through .75s.  Of course, we didn't make the connection between the high rev low pitch thing and the improved airplane performance.  Went back to our Max .35s and ST .46s for a decade or more before somebody back east put two and two together.
Ted
Offline Terrence Durrill
Re: Caprice
« Reply #15 on: October 10, 2011, 10:24:43 AM »
Electrics are fine for those who want to use them and find satisfaction in that variant of control line flying.  Many, however, will never consider electrics because they depart too far from what control line has been for the last 50 years.  It is like the Archer who prefers the classic composite bow to the mechanical monster known as the compound bow.  It just gets too far away from what many have felt control line to be.  No offense to the electric guys, but many control line fliers will never take that route for the reasons I have described......TDurrill    D>K    H^^
Offline Balsa Butcher
  • High Desert Flier
Re: Caprice
« Reply #16 on: October 10, 2011, 10:34:32 AM »
I'm not in favor of tuned pipes in classic. It's bad enough that electrics are allowed (I know,they are waay better than IC engines etc., heard it all but don't believe they are true to the spirit of the event). It could become PAMPA stunt with no skill classes using (mostly) smaller models with undersized horizontal stab/elevators. Is that what we want?  ???
« Last Edit: October 10, 2011, 11:28:17 AM by Pete Cunha »
Pete Cunha
Sacramento CA.
AMA 57499
Re: Caprice
« Reply #17 on: October 10, 2011, 10:51:10 AM »
Ted,
I want to watch Uncle Mikey when you show up with a Chizler with tuned pipe. His face may be the inspiration for a new color.   LL~
Re: Caprice
« Reply #18 on: October 16, 2011, 08:29:31 AM »
I too want to be there for that tuned pipe set up.   Have already seen some of the new stuff being used.   Besides I think you have to get it by Robin and Lou/Lew. LL~ LL~ LL~
Re: Caprice
« Reply #19 on: November 13, 2011, 11:15:49 PM »
I'm thinking that if somebody can e-power a Classic, then a tuned pipe should be just as legal. The e-power does have an advantage, no doubt about that. If you allow electrics and don't allow pipes, then the IC power is just not going to survive in Classic. I'm thinking a Shark 45 would fit a pipe pretty easily. Just offset the nose strut to clear the header.   H^^ Steve
PS: I'm not in favor of electrics in Classic.
Re: Caprice
« Reply #20 on: December 10, 2011, 06:01:25 PM »
A few weeks ago, I took the bull by the horns and sent an email to Robin Sizemore about allowing a tuned pipe in a Classic (at VSC),  pointing out that if electric is allowed, the pipe would only help to even the playing field for IC powered Classics. Robin and Lou aren't buying any of that chit, so the reply was basically "no thanks!".  You can go ahead and enter an electron powered Classic if you wish, but expect some serious frowns from competitors and Appearance Point judges. The piped IC Classic will earn you even harsher treatment. Dang.  LL~ Steve
Re: Caprice
« Reply #21 on: December 10, 2011, 07:54:21 PM »
Yea, that maintains the spirit of the event. Electric and tuned pipes.
Online RandySmith
Re: Caprice
« Reply #22 on: January 09, 2012, 10:46:32 PM »
I do not see how they can possibly dis-allow cf pipes if someone shows up with them, Same for electric classic ships, nothing in the rules to disqualify them, and if you think about it what is the differance between allowing modern Electric power plants but not 25 year old pipe power plants?
Re: Caprice
« Reply #23 on: January 10, 2012, 09:12:53 AM »
In the years I have seen electric in Old Time and Classic.   In Classic there have been planes flown with rear exhaust engines.   I don't really think that Lou or Robin will keep you from flying.   I don't think the judges will care either way and will score you on how well you fly.   My opinion and not theirs. VD~
Re: Caprice
« Reply #24 on: January 10, 2012, 12:10:21 PM »
Bill and Randy,
(snip)
Ted
Hi Ted,
I am brought back to the article on Juri Sirotkin and his 1964  WC.  The prop was ID'ed as about 10" X 4" pitch.
And it was reported his engine was turning pretty fast.  Seems he had one of the first high rpm low pitch that was highly successful! ;D
BIG Bear
RNMM/AMM
Online RandySmith
Re: Caprice
« Reply #25 on: January 10, 2012, 12:32:36 PM »
Hi Ted,
BIG Bear
RNMM/AMM
Hi Bill
There were many many people that used hi RPM 40 or more years ago in Stunt, Even Noblers with FOX 36X turning up along with Johnson and K&B engines spinning very fast. I had profile stunt planes over 40 years ago that I used FOX 36s turning 4 to 4.5 pitch props, along with ST 35s, and a couple of other engines I ran at Hi RPM. This was NOT  uncommon.
Many people back then did try to run the FOX 35 in a very slow deep 4 stroke..kinda like Geiseke did, but the engine almost shutting off in the wingover corner wasn't anything that appealed to me. So when I did use a slower FOX 35 on my Smith Nobler I used the 35 with lots of nitro and a 5 pitch prop.
I got a hint on that by smelling Billy's engine running   ;D, plus there was always lots of Missle Mist hanging around my house
Re: Caprice
« Reply #26 on: January 10, 2012, 03:39:31 PM »
Thanks, Randy.  I was just pointing out to Ted that the World Championships were won this way in 1964.  I ran high rpm/low pitch around 1964.  Not because I knew anything about it, just that was the way the engines liked to run. ;D
BIG Bear
RNMM/AMM
