  • June 16, 2025, 10:25:32 AM
Author Topic: Magician 15  (Read 3520 times)
Offline Leester
Magician 15
« on: December 21, 2009, 12:40:32 PM »
While doing some shop cleaning I saw my Norvel .15 which I've never run and got thinking what I had for it. Looking through my stash I found my Walter Umland Magician 15 kit signed By Jim Silhavy. I got it down and .. well, man I need to build this. Now I'm wondering the Norvel, FP15 or LAS15 I even have a Fox 15 ???? I have so many projects started now whats 1 more  VD~ VD~ VD~ I can see this guy on my shoulder saying you ain't got no BA%$# if you don't !!!
Leester
ama 830538
Offline ray copeland
Re: Magician 15
« Reply #1 on: December 21, 2009, 02:11:41 PM »
Leester,  I also have a Norvel .15 waiting to be used, i believe mine is a ame model and wants to run fast on some sort of pressure. It has about 30 minutes run time on the bench and was very tight when new, it will still lock up tight when flooded! Good luck with the motor you choose, i too have several projects going on including a scratch build Super Firecat, Vector kit and a foam wing .40 size trainer, oh yeah and all the 1/2 a's i want to build!! I am leaning toward a Flite Streak JR. for my Norvel down the road but if you choose to use yours on the little Magician i will be looking forward to the build reports as i love my full size Magician. Happy Holidays!!!  Ray Copeland
Re: Magician 15
« Reply #2 on: December 22, 2009, 05:00:03 AM »
That Magician 15 is a very small airplane.  If one came to me, I would power it with only the lightest of 15's, or maybe a TeeDee .09.
Offline Leester
Re: Magician 15
« Reply #3 on: December 25, 2009, 10:55:29 AM »
Well the Fox 15X is the lightest I have at 3 1/2 oz next is the LAS 15 at 4oz (without muffler).
Love this laser cut kit even has 1/4" jig holes.
Leester
ama 830538
Offline Leester
Re: Magician 15
« Reply #4 on: December 26, 2009, 06:15:12 PM »
The wing goes together fast in the jig, wing tips and center sheeting will just about do it. Thinking the LAS 15 might be my best choice, no muffler required were we fly.
Leester
ama 830538
Offline Leester
Re: Magician 15
« Reply #5 on: December 27, 2009, 05:43:50 PM »
Just have to shape the leading edge and another complete sanding and it's ready for the fuselage.
Leester
ama 830538
Offline Leester
Re: Magician 15
« Reply #6 on: January 02, 2010, 01:34:11 PM »
A little more done on it. Changed my mind and went with the Fox 15X hey they need lovin too. LL~ LL~
Leester
ama 830538
Offline Leester
Re: Magician 15
« Reply #7 on: January 03, 2010, 05:07:07 PM »
Gettin close to finishing time, a bunch of sanding to do then some dope. As it is it's 9 1/2 oz the recommended weight is 15 oz.
Leester
ama 830538
Online john e. holliday
Re: Magician 15
« Reply #8 on: January 04, 2010, 11:22:53 AM »
The construction is looking great.  Too bad the Magician is such a homely plane.  Maybe that is why it flies so well. H^^
  • Gravitywell
Re: Magician 15
« Reply #9 on: January 04, 2010, 12:33:03 PM »
I don't think its homely....in the '30s it would have been considered futuristic!  Wished I had a plan, I would build one myself.  Hmmmm....I do have a McCoy RH .19 H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline Jack Mulinix
  • AMA 917877
Re: Magician 15
« Reply #10 on: January 07, 2010, 12:08:55 AM »
Nice looking Leester, I'm building a Brodak right now. Question, what are you doing for leadout guides? I have glued them right on the tip. Don't know if I like it or not. Construction looks almost identical. Jack
Re: Magician 15
« Reply #11 on: January 08, 2010, 10:42:19 AM »
Hey I built my Brodak Magician box stock.  No adjustable leadouts or weight box.  Flies mucho better than I can with Brodak .25 on 3 once fuel tank, Brodak of course.
Offline Leester
Re: Magician 15
« Reply #12 on: January 09, 2010, 07:20:05 AM »
Jack, I'll do my lead outs just like yours. I believe Walter sold his rights to the kit to Brodak.
Leester
ama 830538
  • AMA 917877
Re: Magician 15
« Reply #13 on: January 09, 2010, 07:38:41 PM »
Hi Leester, about the lead outs, I just don't know how the'll look with the covering on. I had cut some more tips out of 1/8 to make a sandwitch and burry them. Evan made a slider with the same line spacing as on the plans. that was a waste. as you might get 1/4 inch adjustment. Anyways looks good. looking forward to seeing finish and flight reports.
Offline Leester
Re: Magician 15
« Reply #14 on: January 10, 2010, 09:15:30 AM »
Jack, the tips look OK without the adj lead outs. Here's a ARF Nobler wing that I put in a Metaphor 1 (take off of a Magician ) they don't look bad.
Leester
ama 830538
  • AMA 917877
Re: Magician 15
« Reply #15 on: January 10, 2010, 01:06:46 PM »
Thats exactly what i was thinking of doing. With the little blocks, not just the tubes, like mine are now.
  • AMA 917877
Re: Magician 15
« Reply #16 on: January 10, 2010, 01:08:02 PM »
Thanks for the pictures.
