  • July 07, 2025, 01:10:57 PM
Author Topic: How do I get a design verified as classic?  (Read 1770 times)
Offline pat king
    • PDK LLC
« on: July 02, 2011, 11:25:44 AM »
I want to get the Deweybird (45") verified as a Classic design. I have a copy of the plans signed by the designer and dated 1968.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
Offline Tom Niebuhr
Re: How do I get a design verified as classic?
« Reply #1 on: July 02, 2011, 04:10:07 PM »
Sounds like you have the verification.
AMA 7544
Offline builditright
  • So happy to be alive!
« Reply #2 on: July 02, 2011, 06:29:47 PM »
Hi Pat,
I agree with what Tom said, that should do the trick
Thank you and God Bless
Walter
aka/ builditright
« Reply #3 on: July 16, 2011, 04:55:23 PM »
In the case of the Firecat (for OTS), the information was corroborated by sending copies of the evidence to the PAMPA rules chairman. Copies to Allen Brickhaus, Bob Hunt, and Robin Sizemore would be a good idea, too. If the info gets published in SN, FM, MA and somebody flies one at VSC, you're good to go.   y1 Steve
« Reply #4 on: August 09, 2011, 06:28:44 PM »
I was tootling around the PAMPA website (after logging in) and found a place where it said that the PAMPA board of dictators would rule on evidence of newly discovered Classic designs. It would probably help to get your District Dictactor convinced first...i.e., follow the chain of command.  y1 Steve
Offline pat king
    • PDK LLC
« Reply #5 on: August 11, 2011, 09:47:17 AM »
Thanks for the input. I talked to Allen Brickhouse and have posted what he recommended here and on Stuka Stunt.
Thanks again,  Pat
Pat King
Monee, IL
AMA 168941
