  • August 02, 2025, 04:18:11 AM
Author Topic: Cox P-40 help needed  (Read 1572 times)
Offline jsesere
« on: April 27, 2010, 12:53:49 AM »
I have a Cox P-40 Warhawk and I'm trying to pin down the year it was made. If you know about such things and can assist me I would be able to email pictures to you.
Re: Cox P-40 help needed
« Reply #1 on: April 27, 2010, 06:58:39 AM »
I can't nail down the exact Day One, but I'm sure it was on the market by 1962.  I'll try to dig out some old mags & get you something better.
Incidently, the plane debuted the "Super Bee", which was a Babe Bee with a TeeDee 2-port cylinder.  That got everybody I knew (which was quite a few) to upgrade ALL existing Babe Bees and Golden Bees.
Offline Bill Heher
  • Fix-it
« Reply #2 on: May 12, 2010, 09:49:10 PM »
The early version also had the engine inverted I seem to recall. Later were side or top facing cylinder.
Bill Heher
If it's broke Fix-it
« Reply #3 on: May 26, 2010, 11:22:04 PM »
 If the plane is in good enough condition you might take it apart and check this out. Apparently at least some of the Cox planes had a manufacture date stamped with ink inside them. I've got a N.I.B. "Super Sport" that has a date stamped inside the fuse this way. It looks just like an old library stamp or something. If I remember right it's October of 1976 on mine.
