  • June 16, 2025, 05:56:50 PM
Author Topic: Colossus  (Read 1976 times)
Offline James Mills
Colossus
« on: January 23, 2010, 12:38:30 PM »
I have one of Walter's Colossus kits that I'm planning to get into soon.  Did the Colossus ever have fuse mounted landing gear?
James
AMA 491167
Re: Colossus
« Reply #1 on: January 23, 2010, 11:52:33 PM »
I've still got one under the bench. Will get to it eventually.
Offline dennis lipsett
Re: Colossus
« Reply #2 on: January 24, 2010, 12:59:22 AM »
I think that the Umland Colossus was a very limited release. That makes the owners of this kit a very exclusive club. Of course it's magnificent.
Dennis
Offline Gordan Delaney
Re: Colossus
« Reply #3 on: January 27, 2010, 04:37:22 PM »
Jim,
As far as I know they were all wing gear mounted.
Gordy
Re: Colossus
« Reply #4 on: January 27, 2010, 08:26:36 PM »
James
Hi James
You can use a fuse mount  dural , or CF gear on the plane and still be perfectly legal to fly, It would be a good idea to keep it in the same position as the wing mount gear
« Last Edit: February 01, 2010, 06:43:09 PM by RandySmith »
Offline RogerGreene
Re: Colossus
« Reply #5 on: February 01, 2010, 05:27:00 PM »
The original had wing mounted gear. :)
Roger
Fly Stunt <><
AMA 435R
USAF Veteran 1962-66 SAC
Life is 10% what happens to you and 90% of how you react to it. FAA #FA3RFLPAN7
Offline De Hill
Re: Colossus
« Reply #6 on: February 18, 2010, 01:12:32 PM »
The original Colosuss was designed and built on Naha, Okinawa in 1964. It was inspired by the Werwage Ares.
It won Stunt at the USAF Far East Championships held in Tachikawa, Japan in 1964.
« Last Edit: February 18, 2010, 01:49:43 PM by De Hill »
De Hill
