  • July 31, 2025, 11:17:55 AM
Author Topic: Wing trailing edge ?  (Read 2140 times)
Offline Rob Killick
« on: July 03, 2006, 01:55:28 PM »
Heheheh :)
Another wing ? flap question ...
I'm building Brodak's "Oriental" and have followed the plans and instructions to a "T".
I'm ready to fit the flaps , but there is a fit problem .
The trailing edge of the wings (with trailing edge sheeting) is 3/8th's of an inch , but the flap material is only 1/4 inch thick .
I'm using barrel type hinges , not the cloth supplied .
The problem is , there is a noticable "step" from the wing TE to the flap hinge .
Should I get some 3/8th balsa sheet and redo the flaps ?
the 1/4 inch flap material just doesn't look right to me  :!
Rob Killick , MAAC 33300
Offline wmiii
Re: Wing trailing edge ?
« Reply #1 on: July 03, 2006, 03:11:20 PM »
First of all, what do the plans show?  I've done elevators smaller than the stab, but not flaps. It might work just fine. But if your in doubt,
use 3/8 stock for the flaps.
  Walter
walter menges
Offline peabody
« Reply #2 on: July 03, 2006, 03:15:44 PM »
A lot of folks use 1/4" as flap material....there are thoughts that the larger wing root verses the 1/4" flap will "wash" the surface, and correct some hunting issues.
Offline Alan Buck
« Reply #3 on: July 03, 2006, 03:31:25 PM »
the sheet for the trailing edge is tapered the last 1/4inch to match the flap had the same on my kit
ALAN E BUCK
Offline Leester
« Reply #4 on: July 03, 2006, 03:41:32 PM »
Rob: Check your plans and on the side view of the wing you will see the taper on the trailing edge sheeting.
Leester
ama 830538
Offline Rob Killick
« Reply #5 on: July 03, 2006, 09:04:49 PM »
Again , disaster narrowly averted , thanks to you all  %^
This is a great site and I'm storing alot of information that has been provided :)
