  • July 18, 2025, 12:40:39 AM
Author Topic: Which holes at the flap horn for flap and elevator linkage?  (Read 1522 times)
« on: February 09, 2014, 05:53:37 PM »
I'm now rigging up the controls on my Profile Yak-9. I've looked at models and some connect the bellcrank to the top hole in the flap horn, then the elevator to the second hole. Others are reversed. Which is the best starting point?
These are the horns I'm using:
Thanks.
Rusty
Offline RC Storick
Re: Which holes at the flap horn for flap and elevator linkage?
« Reply #1 on: February 09, 2014, 06:04:02 PM »
Here is what I would do but I am sure there are other ways. You can move the elevator rod up if its light.
Im not fixing the TYPO so hold your comments.
« Reply #2 on: February 09, 2014, 07:09:49 PM »
Thanks Robert, I'll do it like that.
Rusty
« Reply #3 on: February 09, 2014, 07:12:38 PM »
     I would suggest making sure that you can change the elevator pushrod on the flap horn to any of the other holes. I would start with much less than 1:1 movement, a lot more elevator than flap.
