  • July 03, 2025, 03:24:25 PM
Author Topic: Cutting a canopy  (Read 1787 times)
Online James Mills
Cutting a canopy
« on: January 26, 2008, 09:52:10 PM »
I posted a how to question for cutting down a canopy to fit the top block.  Are there a certain kind of scissors for this?
James
AMA 491167
Re: Cutting a canopy
« Reply #1 on: January 26, 2008, 09:53:39 PM »
James,
Sharp ones.
Offline Leester
« Reply #2 on: January 26, 2008, 10:29:09 PM »
I use Hobbico curved tip canopy sissors from Tower.
Leester
ama 830538
« Reply #3 on: January 26, 2008, 10:55:25 PM »
Ok, it was supposed to be funny.   :##
I just draw the approximate shape on the canopy and use a pair of scissors to cut it out then trim down until it fits. Then sand paper.
Offline Terry Bolin
  • Havin' the time of our lives!
« Reply #4 on: January 27, 2008, 06:53:49 AM »
Canopy? what are you working on?
James, Send  me a e-mail for the address on the new field. I saw the pictures, looks like a great site.
Online James Mills
« Reply #5 on: January 27, 2008, 11:46:34 AM »
If you do a google map search the addres is 2750 W. Bennett.
I'm getting my Formula S for classic put together, and I've also got the fuse for a Starfire/Temptest framed up and out of the jig.
James
AMA 491167
Online James Mills
« Reply #6 on: January 27, 2008, 11:48:48 AM »
Randy,
I seem to run into problems trying to get the shape close, end up cutting away to much of the canopy.  I just got a couple from Sig, so will see how it goes.
James
AMA 491167
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #7 on: January 27, 2008, 04:43:21 PM »
I'm with Leester, Hobbico curved tip canopy scissors from Tower are the perfect solution. They work great and allow you to follow the line. Highly reccommended...
« Reply #8 on: January 27, 2008, 08:28:15 PM »
James,
Don't try to hit the mark of the first cut. Leave yourself a half inch or so of wiggle room the trim it a little at a time.
Offline Patrick Rowan
« Reply #9 on: January 27, 2008, 10:05:18 PM »
I use the Hobbico scissors. I agree with Randy, trim small amounts at a time or have a couple of extra canopys on hand.
Fly Stunt
75750
Poland, Ohio
« Reply #10 on: January 29, 2008, 08:21:12 AM »
Temporarily securing 60-80 grit sandpaper (grit side out of course!  n~ ) to the fuselage is a very good way to do the final fitting to the fuselage.
I do the same method as Windy (and others, I'm sure) shows on many of his tapes as to cutting a trough in the top block to inlet the canopy.  Gives you even a touch more wiggle room.
