  • June 19, 2025, 09:13:04 AM
Author Topic: Using Duplicolor can paint.  (Read 1753 times)
Offline James Mills
« on: June 22, 2008, 08:52:30 PM »
I'm thinking of using the Dupicolor paint sold in aerosol cans at the paint shop, how much coverage can you expect from the colors?
James
AMA 491167
Online Will Hinton
Re: Using Duplicolor can paint.
« Reply #1 on: June 23, 2008, 04:55:44 PM »
James,
My Ephesian is 746 squares and I used a little over two cans of the yellow.  Keep in mind that it took two coats to get my desired effect because I used a powder blue blocking coat to get the hue I wanted.
Blessings,
Will
« Reply #2 on: June 25, 2008, 05:55:37 PM »
Hi James,
We have been using the *Truck, Van, and SUV* big cans of Duplicolor lacquer for several years.  I have found them to cover a bit better than dope, usually.  Now I am experimenting with the *Paint Shop* quart cans and spraying them on.  That way I can add a *little* flexative and fish eye killer to it.  I shoot urethane 2 part clear over it, and it has held up excellently.   I haven't found a *down side* yet!  The Paint Shop colors are very limited right now, but they have added a *Metallic Clear* and a *Prism Clear* to use between the color and top coats.  There are 8, IIRC, colors right now, but you can easily mix any color you want!  I have a feeling that a stunter will get the *Prism Clear* before too long!
Mongo
Offline Gary Hajek
  • ACE
Re: Using DupliColor can paint.
« Reply #3 on: June 27, 2008, 10:19:56 PM »
  i WAS LOOKING AT  PAINT SHOP COLORS AND IT SAID TO THIN WITH ACETONE IF DESIRED . THEY MAKE AND SELL LACQUER THINNER#CM502 , WHY THIN WITH ACETONE         GARY HAJEK
« Last Edit: June 28, 2008, 04:52:35 AM by Robert Storick »
« Reply #4 on: June 30, 2008, 09:51:04 AM »
Hi Gary,
I am not sure as to why they recommend Acetone.  The Paint Shop paint is a new *synthetic* lacquer, so I chalked it up to that.  The Lacquer thinner Duplicolor sells is for the Filler/Primer and other *Specialty* paints they have. (according to the label)
Bill <><
Offline Larry Wong
« Reply #5 on: July 13, 2008, 09:13:11 PM »
Has anybody try to find out if The Paint Shop paint is a new *synthetic* lacquer, is fuel proof?
Larry
« Reply #6 on: July 18, 2008, 08:44:51 PM »
Hi Larry,
I have not had a problem since I overcoat with either clear dope or, usually, automotive urethane.
I haven't not clear coated in too many years to count...........
Bill <><
