  • July 12, 2025, 01:04:18 AM
Author Topic: Ultracoat Hinges  (Read 947 times)
Offline Richard Koehler
Ultracoat Hinges
« on: September 24, 2011, 06:37:59 PM »
Two years ago when I built my WINGMASTER I decided to try Ultracoat Hinges.  The hinges were tight when I put them on.  Last week when I got that airplane out the elevator was very loose.  Do those hinges stretch over time.  Is it possible to shrink them tight again or should I just get rid of them and put in std pinned hinges?
Offline Frank Imbriaco
Re: Ultracoat Hinges
« Reply #1 on: September 25, 2011, 06:23:55 AM »
If you're running glow power, the exhaust residue will  eventually loosen them.
« Reply #2 on: September 25, 2011, 08:17:14 AM »
Just hit them with the iron again.   If the glue joint has given up, you may need to replace them.   H^^
