  • June 16, 2025, 09:53:22 PM
Author Topic: Fillets and monokote??  (Read 4512 times)
Offline James Holford
« on: June 18, 2018, 11:01:33 AM »
Twister is moving along buy I like to plan ahead.
 Planning on monokoting the Wing and Rustoleum on the fuse. But want to add fillet.
  When or how should I go about this?
I probably should dig through some threads but dont have time.
Thanks.
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Re: Fillets and monokote??
« Reply #1 on: June 18, 2018, 11:49:51 AM »
Hmm - but clearly the rest of us have time to do your research for you?...
  Despite that, cover the wing/tail, leave bare wood at the roots of the wing and tail, for about 1/8" or so being exposed when assembled. After assembly, and after doing the prep work for the fuselage, up to the point of applying filler, use steel wool to rough up the monokote out to the width of the fillet, clean it thoroughly with acetone. Apply the fillets over the end of the Monokote, sealing it permanently at the root. Then finish a little beyond the edge of the fillet with whatever finish you use on the fuselage.
« Reply #2 on: June 18, 2018, 12:10:40 PM »
Thanks Brett.
  I had a few minutes in between jobs to allow me yo make a post. Now Im off work i can do whatever...thanks tho
Jamie Holford
Lafayette, La
AMA #1126767
« Reply #3 on: June 18, 2018, 01:31:23 PM »
When I'm finishing with Rustoleum, I put the wing in the fuse in the bare-wood stage, do the fillets, paint to about 2" out on the wing roots, then 'coat up to about 1" out on the wing roots for plenty of overlap.  Monocoat and Rustoleum have different shades of white, but it's not too bad.
Here is a link to an old build thread of mine with the process to actually lay down the fillets described.  Note where it says "if my fillets fall off..." -- the plane has well over 500 flights on it, possibly 800 or so (I didn't keep good count).
« Reply #4 on: June 18, 2018, 02:16:51 PM »
Tim that is exactly what I needed to read!!! Thanks!!!
Jamie Holford
Lafayette, La
AMA #1126767
« Reply #5 on: June 18, 2018, 02:40:51 PM »
  Do as Brett suggests , then add fillets, or install wing bare, then cover within 1/8" or so of fuselage, then add fillets. The fillets will adhere to the bare wood also, and still seal the covering. This lets the covering bond to the bare wood better than painted surfaces, and seals the edges of the covering down. Every plane I have done this way is still functional and covering still attached.
« Reply #6 on: June 18, 2018, 02:42:02 PM »
  I strongly recommend putting the fillets OVER the edge of the Monokote, that ensures that it will be sealed against fuel intrusion forever.
« Reply #7 on: June 18, 2018, 02:47:06 PM »
Thats how I understood it lol.
 Wing is already installed.. bare, so it will work out just fine.
Thanks yall.
Jamie Holford
Lafayette, La
AMA #1126767
« Reply #8 on: June 18, 2018, 03:12:27 PM »
I haven't had much problems, and the planes have many miles on them.
I do see your point -- I just don't like the idea of gluing down covering material right at the edge like that, at least not on a plane that may be crashed.  (If it's not going to be crashed -- don't use 'coat!)
« Reply #9 on: June 18, 2018, 04:06:14 PM »
Brett's method is the best.  One thing I can say about putting monokote over a fillets is DON'T EVEN TRY.  It can be done but it ain't pretty.  I have done it and it took forever to get something that looks half way decent.  Looks OK standoff but up close, well just don't get up close.  Only way it will work is if the fuselage is also monokoted.  Do the fillets first with strips that will cover the fillet with about 1/4" on both sides.  Use gobs of balsa-rite and tack the monokote down the center of the fillet.  Let the glue set then slowly, using the coolest setting that will melt the glue, work the monokote from the inside out.  Just keep in mind that it wants to shrink and will pull away if you get it too hot.  If that happens, slit the bubble with a knife, iron down the edges and cover it with a thin strip.  Once it shrinks, you have little chance of ever getting that bulge out.
I use Monokote on everything because it is Wife Friendly.  There is not one sq" on the attached that is not monokote.  1/2" fillets on wing, 1/4 on tail.
Good Luck - Ken
Offline Phil Krankowski
« Reply #10 on: June 18, 2018, 06:49:40 PM »
Paint the fillets.  It will be a nightmare to cover any but the most gentle hollows with film.
An undercambered wing is pretty difficult to get covered well without pulling itself free from the hollow bottom.
Phil
« Reply #11 on: June 18, 2018, 06:51:07 PM »
Ok I guess yall misunderstood me lol... i wasnt planning on covering OVER the fillets lol.  I was talking about putting fillets over the monokote THEN painting lol
Jamie Holford
Lafayette, La
AMA #1126767
« Reply #12 on: June 18, 2018, 07:26:27 PM »
    On a model that may be considered expendable, , monokote the whole thing and use silicone caulk as the fillet material, and apply the same way as you would epoxy/micro balloons or Super Fill, or whatever. I think I heard  Keith Sandberg refer to it as "Tube-O-Fillets" when he held up the tube of caulk he was using while assembling a Fllitestreak ARF at the SIG contest one year. It's available in several colors and clear, and can be coordinated with the color of the material used for covering. It sticks to bare wood and covering material well, and is fuel proof. it can be dug out if need be for repairs and replaced. My SIG Primary Force is covered in orange with white trim just like the box and has white bath tube caulk for the wing fillets
« Reply #13 on: June 18, 2018, 07:27:51 PM »
And what alot of peeps dont know is Windex is excellent for making silicone smoooooottthhhhh
Jamie Holford
Lafayette, La
AMA #1126767
« Reply #14 on: June 18, 2018, 09:04:48 PM »
Phil
It can be done if you have the patience of an old Monk and a month with nothing better to do.
« Reply #15 on: June 18, 2018, 09:23:31 PM »
No, we got it, just wanted you to see what you were missing out on!
« Reply #16 on: June 18, 2018, 09:30:43 PM »
Ahhhh
Jamie Holford
Lafayette, La
AMA #1126767
« Reply #17 on: June 19, 2018, 11:17:30 AM »
I was told by someone who flys RC that he uses vinyl striping tape from the auto parts store.  Pressure sensitive adhesive, pliable, and meant to go around curves.  Looked ok on his plane, but the color didn't match.
Phil
« Reply #18 on: June 19, 2018, 11:21:29 AM »
Phil
That is an idea worth looking into.
Offline Skip Chernoff
« Reply #19 on: June 19, 2018, 02:50:03 PM »
Do it exactly the way Brett discussed and you'll have a good looking fuel resistant wing to fuse joint.......PhillySkip
Offline Larry Renger
« Reply #20 on: July 03, 2018, 07:38:53 AM »
Ask Larry Fernandez how he does it.  :D
