  • June 17, 2025, 03:02:26 AM
Author Topic: Tom Morris Big Horns  (Read 1567 times)
« on: March 15, 2020, 11:09:42 PM »
blank
« Last Edit: August 25, 2021, 11:19:50 AM by Motorman »
Online Howard Rush
Re: Tom Morris Big Horns
« Reply #1 on: March 16, 2020, 12:42:58 PM »
If you have Excel, I can fix you up.
Offline Fred Underwood
« Reply #2 on: March 16, 2020, 01:30:01 PM »
What is the bellcrank travel in degrees.  You will need that for Howard's program as well.
Fred
352575
Offline Warren Wagner
  • Bradenton, FL
« Reply #3 on: March 16, 2020, 03:38:34 PM »
You can get just a bit more sophisticated with a simple fixture like this.
The ruler displays the amount of HANDLE/CABLE displacement.
The left hand plywood "tee" represents 1/2 of the BELLCRANK.
The plywood "tee" on the right represents the FLAP HORN.
The protractor displays the displacement of the FLAPS (and
elevators, if 1:1 ratio is utilized.)
Put in as many adjustment holes as deemed necessary, and play with
different combinations to get the elevator range that you want.
The fixture is handy, simple, and and gives you good results, but not
as good as Howard's Excel program.  <g>
Cheers.
Warren Wagner
Warren Wagner
AMA 1385
Online Lauri Malila
« Reply #4 on: March 19, 2020, 07:58:52 AM »
Are you sure that ball bearings in that place is a good idea? 🤔
L
