  • June 16, 2025, 01:47:07 PM
Author Topic: Building the new Shark 35 Profile  (Read 7902 times)
Online Mike Griffin
« on: January 08, 2017, 07:55:20 PM »
Thought I would share some pictures I have taken while building the prototype of the new Shark 35 Profile kit I have come out with.  Basically this is the same wing and tail components that are on the full fuselage version of Lew McFarlands Shark 35.  All I had Eric Rule do was cut a profile fuselage instead of a full fuselage.  I hope you like it and please feel free to contact if you would like to order a kit.
I built the wing first so thought I would post those first.
This first picture is the plywood reinforced ribs where the tricycle gears will be mounted.
« Last Edit: January 08, 2017, 08:20:06 PM by Mike Griffin »
Online Mike Griffin
Re: Building the new Shark 35 Profile
« Reply #1 on: January 08, 2017, 07:57:09 PM »
An optional wing rod jig if you wish.  This can be modified for any wing.
Online Mike Griffin
« Reply #2 on: January 08, 2017, 08:03:57 PM »
More
Online Mike Griffin
« Reply #3 on: January 08, 2017, 08:05:25 PM »
More
Online Mike Griffin
« Reply #4 on: January 08, 2017, 08:07:10 PM »
More
Online Mike Griffin
« Reply #5 on: January 08, 2017, 08:10:42 PM »
Starting the fuselage
Online Mike Griffin
« Reply #6 on: January 08, 2017, 08:11:45 PM »
More
Offline badbill
« Reply #7 on: January 08, 2017, 08:18:15 PM »
That's sweet! Do the ribs have tabs so it can be built without a jig?
Bill Davenport
AMA 28141
Online Mike Griffin
« Reply #8 on: January 08, 2017, 08:24:47 PM »
No Bill not right now but they could probably be easily added to the cut file.  I don't show it in these pictures but I actually built this on my Jim Snelson Jig which Bill Lee makes now.
Online Mike Griffin
« Reply #9 on: January 08, 2017, 08:29:10 PM »
The airfoil on this wing is for modern day stunter.  Click on the paper clip attachment below to see a PDF of the plan.  The flaps have been lengthened on the root ends to accommodate a profile fuselage.
Offline rich gorrill
« Reply #10 on: January 09, 2017, 03:30:26 PM »
Mike, do you sell the wing jig? And if so how much is it.
thanks, Rich
Online Mike Griffin
« Reply #11 on: January 09, 2017, 07:24:35 PM »
Hi RIch
Yes the Jig is $39.95
Thank you
Online Mike Griffin
« Reply #12 on: February 22, 2017, 02:41:29 PM »
More
Online Mike Griffin
« Reply #13 on: February 22, 2017, 02:42:46 PM »
Rudder and dorsal
Online Mike Griffin
« Reply #14 on: February 22, 2017, 02:48:51 PM »
More
Online Mike Griffin
« Reply #15 on: February 22, 2017, 02:50:17 PM »
More
Online Walter Hicks
« Reply #16 on: February 22, 2017, 03:40:55 PM »
What size are the holes in the wing Jig for the rods ?
Online Mike Griffin
« Reply #17 on: February 22, 2017, 04:24:53 PM »
Walter
The holes are 3/16' the OD of a Carbon Fiber Rod.
Online Walter Hicks
« Reply #18 on: February 22, 2017, 08:28:25 PM »
Thanks for the reply, I am looking for 5/16 rods OD as I use mostly Pat Johnston designed  ribs and they are cut for 5/16. The pictures look like the
holes are bigger than 3/16?Who sells the wing jig? RSM or you?
« Reply #19 on: February 22, 2017, 09:43:00 PM »
Pat knows the arrow shaft nomenclature and I forgot, email him and he can tell you what arrow shafts to get, I prefer aluminum arrow shafts over carbon fiber, the carbon wicks CA and other glues stick to it really good, I know for me that can be an issue,,
Online Mike Griffin
« Reply #20 on: February 23, 2017, 10:25:11 AM »
Walter you might want to give Eric at RSM a call. I think he can cut those holes in the jig any size you want.
« Reply #21 on: February 23, 2017, 10:28:28 AM »
Don't airfoil the stab. Oops I said it!! :-X
Online Walter Hicks
« Reply #22 on: February 23, 2017, 03:38:53 PM »
Excellent thanks for the reply Mike.
Offline Steve Dwyer
« Reply #23 on: March 19, 2020, 05:03:22 PM »
Mike,
Looks good, question, does the kit provide an airfoil configured rudder fin?
