  • July 11, 2025, 04:50:54 AM
Author Topic: Panel lines?  (Read 1372 times)
Panel lines?
« on: May 05, 2008, 06:38:58 PM »
Alright, lets hear from the panel line pros out there. What's the best way to get thin, sharp lines? They will be on a doped finish with clear dope over them.
(to Randy Powell, at VSC you mentioned some article to read on them but I forgot what it was.)
Offline Crist Rigotti
Re: Panel lines?
« Reply #1 on: May 05, 2008, 08:46:02 PM »
I use Staedtler pigment liner Sketch Pens.  They come 4 to a pack.  .1mm  .3mm  .5mm  .7mm  I have 1 set now for three years.  They "erase" with alcohol and I dust the new lines with clear dope with my airbrush to seal the lines.  They only cost me $10.
http://www.dickblick.com/zz207/57/
Mike Griffin
Re: Panel lines?
« Reply #2 on: May 06, 2008, 01:38:08 PM »
Clint I use the very thin (1/16") striping tape and clear coat over them.
Re: Panel lines?
« Reply #3 on: May 06, 2008, 04:03:22 PM »
Clint,
I'll email it to you. Surprise, I found it.
Re: Panel lines?
« Reply #4 on: May 06, 2008, 08:15:48 PM »
Thanks for the tips guys.
Randy, I got the Email. Thanks a bunch!
Offline Shultzie
Re: Panel lines?
« Reply #5 on: May 07, 2008, 11:01:09 AM »
Also...remember whether or not you use those new pens....THINK CLEAN CLEAN CLEAN...as the surface must be free of all finger prints. Although I don't advocate some harse cleaners such as Prep-sol and Naptha.  I have had good results using my rapid-o-graph pens with the "etch" formula that seems to work ever so beautifully and can be cleaned with a watered down soft paper towel wetted with "Earth friendly-No Chlorine, Perfume or Dye...Hasn't scratched yet..over 120 years BON AMI POLISHING CLEANSER. seems to work amazingly well for me over the years.
Plus it rinses clean, clean, clean with no residue. Remember that sooooo many cleaners "scratch dirt and fingerprints away...Bon Ami's soft abrasives are unique.
Try it.....we used this in the wind tunnel for many projects that we could not use Naptha or Prep-sol based cleaners???
Don Shultz
Offline RC Storick
Re: Panel lines?
« Reply #6 on: May 07, 2008, 11:12:56 AM »
Yep I like BON AMI  pie!
