  • June 19, 2025, 10:23:38 PM
Author Topic: Thrustline alignment  (Read 996 times)
Online Larry Renger
« on: December 15, 2010, 01:46:23 PM »
Here are a couple of photos of the setup I use to align my motor.  The model is leveled with a Robart gage, then the motor is set with the attached level.  Second photo is more detail on the opposite side of the level.
Offline Allan Perret
  • Proverbs
Re: Thrustline alignment
« Reply #1 on: December 16, 2010, 08:19:43 AM »
So what is your target for motor thrust line ?
Any up or down thrust ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Jim Oliver
« Reply #2 on: December 16, 2010, 08:28:26 AM »
Larry,
Do you make any compensation for the "droop" caused by the weight of the indicator?
Jim Oliver
AMA 18475
Online Larry Renger
« Reply #3 on: December 16, 2010, 09:04:23 AM »
I go for 0-0 thrustline, and the indicator is light plastic, so there is no discernable droop to worry about.
The level is just glued to a board, and several sizes of holes are drilled to accomodate different prop shaft sizes.  There are even smaller, lighter levels available and you could probably adapt a bubble level to the job.  Get creative!
