  • August 01, 2025, 09:59:22 PM
Author Topic: this could help  (Read 1174 times)
Offline Igor Burger
this could help
« on: February 20, 2007, 05:02:46 AM »
Offline frank carlisle
Re: this could help
« Reply #1 on: February 20, 2007, 06:10:10 AM »
excellent sequence and very nice workmanship Igor. Thankyou.
I would be interested in seeing how you hold down the tail end of the fuel tank in the plane. And how you go about connecting the pushrod during assembly.
Frank Carlisle
Offline Igor Burger
Re: this could help
« Reply #2 on: February 20, 2007, 06:16:42 AM »
The tank is on short screw on both sides, just taht rear ha two holes for tanks of different volume:
« Last Edit: February 20, 2007, 06:44:26 AM by Robert Storick »
Offline Igor Burger
Re: this could help
« Reply #3 on: February 20, 2007, 06:22:51 AM »
Assembing is simple, first I attach pushrod to tail. then I mount tail and pushrod is in hole for wing. That gives enough space (approximately 1 inch between top of wing wing and bottom of fuselage) for inserting to the flap horn and fixing ... then I mount wing to the fuselage
if you can imagine wing attached to that bottom dismountable part (picture below), you will know what I mean
« Last Edit: February 20, 2007, 06:43:57 AM by Robert Storick »
