Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 19, 2025, 01:54:46 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Building techniques
(Moderator:
RandySmith
T/E shear webs
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: T/E shear webs (Read 1551 times)
Bootlegger
22 supporter
Trade Count:
0
Admiral
T/E shear webs
on:
April 18, 2013, 01:33:11 PM »
Guy's what is the best way have you found to install trailing edge shear webs?
Please be specific..
Thanks.....
Logged
8th Air Force Veteran
Gil Causey
AMA# 6964
Doug Moon
25 supporter
Trade Count:
0
Admiral
Re: T/E shear webs
Reply #1 on:
April 18, 2013, 01:43:25 PM »
Hello,
I measure the inside to inside on the TE sheeting top and bottom right next to where it connects with a rib.
Then I use my blasa stripper and cut a piece of 1/16" at that measured distance. T
hen I cut it to length bewteen ribs.
Then using my x-acto I place one in place and hit it with thin CA.
Then I move to the next bay and cut it and glue it etc...
Logged
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Bill Little
2017
Trade Count:
0
Admiral
Second in COMMAND
Re: T/E shear webs
Reply #2 on:
April 18, 2013, 06:31:55 PM »
Hi Brother Gil,
I use the "inside" function on a standard caliper to get the height of my cuts, and use a Stripper like Doug does. Got this from Mr. Bob Hunt, and there is a post somewhere on the site showing him doing it.
Logged
Big Bear
AMA 95351 (got one of my old numbers back!
Bootlegger
22 supporter
Trade Count:
0
Admiral
Re: T/E shear webs
Reply #3 on:
April 20, 2013, 02:38:53 PM »
Thanks Guy's, I appreciate the help...
Logged
Gil Causey
AMA# 6964
Gordon Tarbell
25 supporter
Trade Count:
0
Captain
Re: T/E shear webs
Reply #4 on:
April 25, 2013, 09:45:02 PM »
which direction should the grain be running on these bits? I was under the impression that the grain should run top to bottom for max strength effect.
Logged
Gordon Tarbell AMA 15019
Jim Thomerson
Trade Count:
0
Admiral
Re: T/E shear webs
Reply #5 on:
April 26, 2013, 02:14:39 PM »
Top to bottom is probably best. However, I do them with the grain running lengthwise, and have no complaints.
Logged
M Spencer
Trade Count:
0
Admiral
Re: T/E shear webs
Reply #6 on:
May 06, 2013, 07:45:20 PM »
Top to bottom for a ridgid wing , such as a twin spar , wwith Vertical Grain sheer webs at Mainspar .
For a Flexi Wing , along the span. The SAME as the SPAR .
or we get the dreaded Fokker torsional control revearseal wing warp / flutter , ' stearage ' .
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Building techniques
(Moderator:
RandySmith
T/E shear webs
