  • July 05, 2025, 09:19:53 PM
Author Topic: TUTOR  (Read 1546 times)
Offline John Desrosiers
TUTOR
« on: May 16, 2011, 09:59:32 AM »
I would like to know every thing I can before starting my Top Flite Tutor. What engine and tank to use. Is it an easy build? This is an old kit from the 70,s or 80,s Thanks for any info.
Online Paul Taylor
Re: TUTOR
« Reply #1 on: May 16, 2011, 09:38:59 PM »
Kreth McKey has the only Tutor I have seen other then then ARF Tutor II. It is a little smaller then the II.
Kreth has a Fox .35 on his and it flies the pattern just fine.
LA .46 is my engine of choice, but might be a little too much power  for the Tutor if there is such a thing. LL~
Online Paul Taylor
Re: TUTOR
« Reply #2 on: May 17, 2011, 10:06:55 AM »
Hi Paul. Like I stated, it depends on the weight of the wood in the kit. Early kits were noted for heavy balsa. Balsa wood is balsa wood. NOT. D>K
I hear ya Ty. Maybe with a heavy Tutor the 46 is in order. Kreth built his very light. Matter of fact the tail was so thin you could see it twist in flight.  H^^
Re: TUTOR
« Reply #3 on: May 25, 2011, 06:46:19 PM »
THANKS GUYS I STIL NEED MORE INFO
Re: TUTOR
« Reply #4 on: May 25, 2011, 06:52:25 PM »
The kit comes with a clear canopie. Not in my kit, Whould enyone have one that they dont need? Please let me know.
Re: TUTOR
« Reply #5 on: May 25, 2011, 06:56:42 PM »
OH boy, my speling is realy bad huh. See I did it again
Online afml
Re: TUTOR
« Reply #6 on: May 26, 2011, 05:28:10 AM »
Hi john,
If no canopy can be located, just make one out of balsa and sand to shape.
It'll last A LOT longer than the plastic one.
"Tight Lines!" H^^
Wes
Wes Eakin
Online Paul Taylor
Re: TUTOR
« Reply #7 on: May 26, 2011, 09:00:45 PM »
And if you really want a plastic on they are real easy to make with a large plastic soda bottle and a heat gun.
You will have to make a plug out of wood, then cut the bottom of the bottle out and shove it in tight. Heat it and it will draw around the plug. If you have a colored bottle even better.
