  • July 07, 2025, 08:02:12 PM
Author Topic: Tanager looking for bird seed  (Read 27400 times)
Offline Carl Cisneros
Re: Tanager looking for bird seed
« Reply #100 on: April 19, 2017, 07:04:55 AM »
Chris;
My Excalibur109 weighs in at 43oz. with battery installed.
But flying it, it seems lighter to me.
The 2k does take time to set up properly, especially in COOLER weather.
But once it cures, you can pour 60% nitro fuel on it and it laughs at it.
Carl
Carl R Cisneros, Dist IV
Control Line RB
Offline Chris Fretz
« Reply #101 on: April 22, 2017, 08:29:35 PM »
Well the Roadrunner/Tanager seems to have finished at 47oz. Good bad?  Any thoughts?
Formerly known as #Liner
AMA 1104207
Advanced
« Reply #102 on: April 22, 2017, 11:07:17 PM »
That looks really good. I guess you'll reach around with your left hand to adjust the needle. My Shoestring was set up like that. It protects the needle if you can get to it easily enough.
Get a camera on it at the field so we can see your first flights.
What prop are you starting with? My old blue(and black) LA 46 likes an APC 12x4. I think my Cardinal was in the same weight range, that should be fine.
Rusty
Offline Chris Fretz
« Reply #103 on: April 23, 2017, 05:52:20 AM »
Rusty
Thanks Rusty! The needle sucks but the fuel line is a straight shot. I'll get the mobius on it, I need to get out and shake the dust off. I am giving the Zoar 12x4 a shot.
Chris
AMA 1104207
Advanced
« Reply #104 on: April 23, 2017, 07:48:26 AM »
Chris
I like the Xoar props.  I use the 12-4 on my LA. If I use a different brand I use the APC 12-4
Question,,,,,,,,,,,, Is the landing gear set right. Looks like a bit back set is all. maybe the pictures tho.
Carl
Control Line RB
« Reply #105 on: April 23, 2017, 08:59:37 AM »
Chris
...Question,,,,,,,,,,,, Is the landing gear set right. Looks like a bit back set is all. maybe the pictures tho.
Carl
Good catch. My Twister built like that and I worried about nosing over in the grass, so I bent it forward. I like to be able to stand behind the wing where I can look straight over the LE and see at least most of the wheels. I was doing my best landings ever with them set rearward, but moving them forward didn't affect it badly.
Rusty
Offline Chris Fretz
« Reply #106 on: April 23, 2017, 02:29:31 PM »
Second one ready to go.
AMA 1104207
Advanced
Offline Chris Fretz
« Reply #107 on: April 23, 2017, 02:36:48 PM »
Chris
Carl
They both are set back.  The plans called for them to angle back like that so I just built it how the plans were.  Don't know what it will be like. I've never had a airplane with the gear set back like that.
Chris
AMA 1104207
Advanced
« Reply #108 on: April 23, 2017, 04:01:03 PM »
I hate to pick on little stuff, and I can't see from the pics, but make sure none of the spinner cutouts are touching the prop anywhere.
Offline Chris Fretz
« Reply #109 on: April 23, 2017, 06:40:35 PM »
What does it do if it does touch?
Chris
AMA 1104207
Advanced
« Reply #110 on: April 24, 2017, 04:05:15 AM »
Your plane will spontaneously explode into a fireball.
Offline Chris Fretz
« Reply #111 on: April 24, 2017, 07:09:39 AM »
Waaaaaaaaaaaaaaaaaaaaaaaaa!  f~ j1 SH^
AMA 1104207
Advanced
« Reply #112 on: April 24, 2017, 01:03:32 PM »
 ;D
Offline Chris Fretz
« Reply #113 on: April 24, 2017, 02:15:35 PM »
;D
Ha ha I'm not sure if you are poking fun or what.  (Meanwhile cussing out the spinner  R%%%% cause it keeps touching when I tighten it.  **))
AMA 1104207
Advanced
« Reply #114 on: April 24, 2017, 03:40:10 PM »
Who, me, poke fun? Of course I am.
Looks like you have plenty of clearance on one side. Turn it so it touches that side so it'll move when you tighten it and clear both sides.
Offline Chris Fretz
AMA 1104207
Advanced
