  • July 08, 2025, 08:10:27 AM
Author Topic: Tail wheel wire suggestion  (Read 1207 times)
« on: August 25, 2008, 10:06:50 AM »
OK, dumb quesiton time. What diameter wire do you usually use for tail wheel wire?
Re: Tail wheel wire suggestion
« Reply #1 on: August 25, 2008, 10:56:05 AM »
Well, without other suggestions, I decided to get a spread of sizes ranging from .062 to .085. I suspect some of it will work.
Offline Ward Van Duzer
« Reply #2 on: August 25, 2008, 11:18:15 AM »
I suspect the most popular size would be 1/16th (or .0625). However, I prefer the 5/64th (.07812). Not quite as springy, a little stronger if you're hanging your planes by the tail wheel, or stooging.
W.
« Reply #3 on: August 25, 2008, 06:35:16 PM »
Hi Ward,
Yea, I just ordered a spread. I'll use if for something.
Offline Bootlegger
« Reply #4 on: August 25, 2008, 07:09:36 PM »
     I'm with Ward, 5/64"  is a good size for all the reasons that he stated... #^
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Al Rabe
« Reply #5 on: August 25, 2008, 09:26:43 PM »
I also use the 5/64" for all of my airplanes.  I notice that it has more spring to it in the rollout than you might think.
Al
Offline Greg L Bahrman
« Reply #6 on: August 25, 2008, 10:25:39 PM »
When using the 1/16, I always had trouble with the launcher leaning to hard on the tail wheel creating problems at release. It was reuced with the larger wire.
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline Gary Anderson
« Reply #7 on: August 25, 2008, 11:25:20 PM »
Hi, does he crush your wing. This is something most people have a hard time doing. I only have a few that I'll let crush my toy. Some launcher will even turn the plane in for you just to see if you can handle the challenge. I only have 1/8" landing gear on my Stiletto and to get a good launch the person has to use the finger tip method. Hey! how about the launcher that will turn loose your plane about the time you pick up the handle! Most I fly with have done this before so they know better than to let loose of the plane before the hand signal. Aren't our toys just a bunch of fun. Randy I send you some jokes, hope its cheers you up. Big question Randy did you get over your surgery you had a while back? Have a great day, Gary
Gary Anderson
« Reply #8 on: August 26, 2008, 08:49:05 AM »
Gary,
Yea, I'm fine. Just busy.
