  • July 05, 2025, 03:00:35 PM
Author Topic: Stooge for Trike part 2  (Read 1468 times)
Offline Jim Treace
  • 1979 600 Aerostar N79JT
« on: April 04, 2011, 10:37:11 AM »
This is a revisit of a thread started last September. Since then I have been working on my Bellanca project (1969 Jim Young's plans)...a trike gear set up. I mostly fly off a stooge and this is my first trike. So, reading the old post I got a kind of idea from Randy Ryan's trike stooge set up. I permanently secured a stooge hook mid line under fuselage aft of nose. This would allow a multi strand wire to be clipped to the hook that would extend aft of the LG and at end of wire a small loop that would engage the stooge pull pin. I use the standard stooge supplied by Brodak. It's a small profile mounted to wood board, secured to ground, would sit under the plane. See photos. I show the photo of Smoothie on stooge just for reference of the stooge device I use. The underside of the Bellanca shows a colored cord to simulate the wire and a loop around a balsa stick to simulate the point where it would engage the stooge pin.
So, big question....will this work?
Jim
Jim Treace
Ponte Vedra Beach, FL &
Paris, TN
AMA 855251 "Too soon we grow old...Too late we grow wise"
Online Paul Taylor
Re: Stooge for Trike part 2
« Reply #1 on: April 04, 2011, 01:59:16 PM »
Hey Jim,
It should work. The only suggestion is that you check the wire from time to time.
I took some old lead out wire and did about the same thing on my Flite Streak, under the tail. The wire would dangle in the breeze behind the plane.
I thought you had a group of guys around Jacksonville?
And you Bellanca looks great !!!
Offline Chris Edinger
  • Hawker Hurricane
« Reply #2 on: April 04, 2011, 04:11:04 PM »
might the wire dangling from under the fuse tend to beat up the fuse some?? or did I read it wrong???
Lee's Summit MO
AMA 896082
Offline James Mills
« Reply #3 on: April 04, 2011, 05:56:49 PM »
Jim,
A stooge with two vertical arms that hold the stab in place would work very well and not require adding anything to the plane.  I think I posted a pic of mine some time back.  It only cost a couple of bucks to build (some plywood, a dowl to cut for the arms, eyelets and a pin to lock it in place), drill some holes in the plywood base and pin to hold down.
James
AMA 491167
« Reply #4 on: April 04, 2011, 06:40:02 PM »
I like it Jim, I think it'll work just fine, the only reservation I have it the engine trying to yaw the airplane while its on the stooge, let us know how that works out. I think my future trikes will have sort of a reverse arresting hook that is spring-loaded in the up position so that when its release it "retracts" and doesn't beat up the fuse.
Offline Jim Treace
« Reply #5 on: April 04, 2011, 09:58:19 PM »
Good input. Maybe instead of a multi strand wire (cable), I'll use a solid wire more securely fixed to the fuselage hook. It would be less prone to swing around. Rather just lay out straight...maybe?
Jim Treace
Paris, TN
« Reply #6 on: April 05, 2011, 06:11:38 PM »
Or maybe a piece of nylon string, check the loops often for fraying.
