This is a revisit of a thread started last September. Since then I have been working on my Bellanca project (1969 Jim Young's plans)...a trike gear set up. I mostly fly off a stooge and this is my first trike. So, reading the old post I got a kind of idea from Randy Ryan's trike stooge set up. I permanently secured a stooge hook mid line under fuselage aft of nose. This would allow a multi strand wire to be clipped to the hook that would extend aft of the LG and at end of wire a small loop that would engage the stooge pull pin. I use the standard stooge supplied by Brodak. It's a small profile mounted to wood board, secured to ground, would sit under the plane. See photos. I show the photo of Smoothie on stooge just for reference of the stooge device I use. The underside of the Bellanca shows a colored cord to simulate the wire and a loop around a balsa stick to simulate the point where it would engage the stooge pin.
So, big question....will this work?
Jim
