  • July 03, 2025, 10:20:17 AM
Author Topic: Staris build thread  (Read 9934 times)
Online Matt Colan
Staris build thread
« on: September 16, 2014, 09:11:33 AM »
In the middle of the spring semester, I got the urge to want to start building something. My friend, now roommate is scratch building a turbine powered F-16 and that's what gave me the idea to build a new stuntship. I decided I would put together a Randy Smith Staris since it's a fairly small airplane and can fit in my car. Power for this new plane will be a PA 51 on a pipe. My target goal is to keep the plane around 55 ounces ready to fly.
I'm using Bob Hunt's lost foam wing jig after seeing how well it went together for my Thundergazer. I'm also trying out his new fully sheeted wing system as well.
So far I have a flap tapered and sanded, one cut, the rudder built, fuselage framed up and the ribs cut and sanded. Building this will probably be slow going trying to balance it between schoolwork and flying.
Offline Steve Fitton
Re: Staris build thread
« Reply #1 on: September 16, 2014, 05:50:37 PM »
Looking good!  I bet that house beats a dorm room for building!
Online Matt Colan
« Reply #2 on: September 16, 2014, 08:37:13 PM »
That picture was taken last semester in the dorm.  Right now I'm building off the kitchen table because it's too hot to go in the garage to build.  My roommate and I built three workbenches for us to use when it cools down here in Florida
Online Matt Colan
« Reply #3 on: September 21, 2014, 06:39:16 PM »
I built the stab over the weekend. It came out  a couple 10ths heavier than I wanted but I'll be able to live with it.
I spent the day up at Jacksonville flying so I'll post a pic of the completed stab sometime later on during the week. I'll be getting started on the wing this week as well.
Online Matt Colan
« Reply #4 on: September 23, 2014, 06:46:54 PM »
Here's a couple pictures of the stab. I ordered the controls from Tom Morris so I should have them in the mail by the end of the week. I'm also hoping to have the wing framed up by the end of the week.
I'm also including a picture of my roommate and I's garage/workshop. Not to many college students have this kind of setup in their house and having the time to be able to use it  ;D
Offline Curare
« Reply #5 on: September 23, 2014, 09:56:32 PM »
Dude, that workshop is waaay to clean, get in there and make some dust!
You can sleep when you're dead!
Greg Kowalski
AUS 36694
Online Matt Colan
« Reply #6 on: September 23, 2014, 10:04:22 PM »
I've been building on the kitchen table because it's been too hot to go in the garage.  I do plan on migrating in there this weekend though!
Online Matt Colan
« Reply #7 on: September 30, 2014, 01:00:17 PM »
Schoolwork has gotten in the way of working on the Staris but I have managed to get the elevators built and one of them sanded. Once I get past Thursday when I finish the four tests I have this week, I'll be able to get started on the wing.
Online Matt Colan
« Reply #8 on: October 13, 2014, 02:34:27 PM »
I have the wing framed up and I'm starting to get ready to mount the bellcrank, if only I had less school work.
The weight of the wing at this stage sits at 5.8 ounces.
Offline Curare
« Reply #9 on: October 13, 2014, 11:14:17 PM »
NAICE! 8)
Greg Kowalski
AUS 36694
« Reply #10 on: October 14, 2014, 01:03:34 PM »
I see honey roasted oats are good for mixing epoxy.... n~
Online Matt Colan
« Reply #11 on: October 14, 2014, 01:54:22 PM »
 LL~  When I had my grandfather send down a bunch of stuff for the plane (motor, engine pads, cowl, wingtips etc.) he felt the need to include some cardboard for mixing epoxy on.  I try and save a bunch of empty cardboard boxes for mixing epoxy on.
« Reply #12 on: October 14, 2014, 02:36:40 PM »
Don't the credit card companies have you in their sights yet?  Jeeze, given that you're a student I expect that you'd be getting boatloads of epoxy mixing cards in the mail.
« Reply #13 on: October 14, 2014, 05:38:08 PM »
The bottom of empty beer cans make good epoxy mixing bowls...
Online Matt Colan
« Reply #14 on: October 15, 2014, 06:03:13 AM »
Thankfully I haven't been spammed yet by the credit card companies. Hopefully they never find out where i live!
« Reply #15 on: October 15, 2014, 08:44:30 AM »
As I learned a long time ago,  paper and card board are bad material to mix expoxy on.   I use plastic or metal lids.
« Reply #16 on: October 15, 2014, 08:56:23 AM »
Heavy gauge aluminum foil might be the ideal mixing surface.  Its about as clean chemically as you can get.
And, sorry, Matt.  We seem to be defacing your build thread with epoxy comments...(!)
Online Matt Colan
« Reply #17 on: October 15, 2014, 05:49:47 PM »
It's not a problem Steve! I'm getting read for Huntersville, which includes cleaning of the kitchen table so that we have a place to eat again. I'll get back to the plane after I get back..
Online Matt Colan
« Reply #18 on: November 18, 2014, 08:28:03 PM »
Been a while since I've posted anything. I have gotten some work done on the Staris. All the control surfaces are done with the exception of hinging and getting a final sanding on everything.
Here's a couple pictures of the PA 51 mounted in the fuselage.  I'll be lucky if I'll be able to get much work done on the plane by the end of the semester. I may be able to sneak in an hour here and there but no real large chunk of time.
« Reply #19 on: November 18, 2014, 08:47:23 PM »
You're making faster progress on yours than I am on mine!  Of course, the step that I'm currently stuck on is getting an RC build out of the way so that I can start working on a stunter.
Online Matt Colan
« Reply #20 on: November 19, 2014, 06:45:20 AM »
You're gonna have about a month to catch up when I head home for winter break in a little less than a month! During my break at home, I'll be touching up my Thundergazer for the NATS, and putting together an Extremeflight 91" Yak-54 for some 3D RC fun!
« Reply #21 on: November 19, 2014, 08:57:48 AM »
Hey Matt, a few minutes here and a few minutes there and it will be done before you know it.
Online Matt Colan
« Reply #22 on: November 20, 2014, 01:01:26 PM »
It turns out my workload isn't as high as I thought it was going to be, so I may be able to get some work done on it before I head home for Thanksgiving!
Online Matt Colan
« Reply #23 on: November 29, 2014, 04:47:31 PM »
Last week I had one of those college weeks where I was being deprived of sleep.  A trip home for some turkey was in order! However, during that awful school week, I managed to find a couple minutes to cut and tack glue the top block onto the fuselage.
When I got home, I got to piece together a project I'll be getting ready to fly for Christmas break, an Extremeflight 91" Yak.  Power will be a DA 60 on a tuned pipe with Savox 1270 Titanium Gear servos on high voltage. I put my grandfather's 60" Yak in front of mine for a little size comparison
I'm currently sitting at JFK airport waiting to head back to school.  I should be able to get a decent amount of work done on the Staris before I fly home again in 11 days.
Online Matt Colan
« Reply #24 on: January 06, 2015, 09:02:42 PM »
Got back from winter break last night, and got down to business immediately on the Staris.  I'm hoping by this weekend to have the stab and elevators hinged, and the fuselage carved.  Going to try and get as much work done on the plane before the schoolwork grind really starts.
