  • July 08, 2025, 12:02:35 PM
Author Topic: squaring up a profile stunter  (Read 1831 times)
Offline Ty Marcucci
« on: July 07, 2007, 08:48:07 AM »
 I square up the tail feathers on a stunter. Here is how I do a profile. The model is a "Trophy Trainer".
The forms used to hold the flaps at neutral are from the TutorII ARF and fit this wing too. Also many others .   The fuselage jig is one I made copying one presented on another forum a few years
back . I also use squares to make sure things are vertical, plumb and square.  On the stab I use a small, light  bubble level along with the 3/16" spruce sticks to get things square.  H^^
« Last Edit: August 02, 2017, 04:33:35 PM by Ty Marcucci »
Ty Marcucci
Offline captcurt
Re: squaring up a profile stunter
« Reply #1 on: July 07, 2007, 09:11:32 AM »
The only thing I would add to this is to be certain that the fuse jig uprights are not FORCING the fuse to be straight while in the jig.  It needs to just sit there in its free state while the wing and stab are aligned.  If you force it straight, or take out a twist, then glue in the wing and stab, as soon as you remove the whole thing from the jig, the fuse relaxes and the alignment is off.
I use a similar setup that has adjustable square backtops to square the stab and wing to the fuse.  Same setup for alignment of full fuse stunter as well.
FWIW
Curt
Offline Bootlegger
« Reply #2 on: July 07, 2007, 02:58:21 PM »
 S?P  Ty, That looks like a good way to do things. I like the idea about using a depth or length gage to get the stab and wing aligned also.
  For a fellow not "from around here" you do right well...LOL...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #3 on: July 10, 2007, 11:11:44 AM »
Heh, heh, I think it beats the heck out of boxes of shot gun shells.  LL~ H^^
 VD~
