  • June 17, 2025, 02:22:51 PM
Author Topic: Fuselage & Wing Jig  (Read 3481 times)
Offline Kelly Wilson
Fuselage & Wing Jig
« on: April 23, 2011, 03:39:09 PM »
I recently bought a set of the Tom Morris fuselage jig brackets and a set of the Tom Morris Lincoln Log wing jig brackets. They come with no instructions and I guess they figure if you are smart enough to order them you will figure out how to use them. I have several schemes in mind to build a base for both of these, but I thought I would see of any of you have used these and what type of base setup you come up with.
Any ideas and pics would be appreciated.
Offline Allan Perret
  • Proverbs
Re: Fuselage & Wing Jig
« Reply #1 on: April 23, 2011, 04:13:47 PM »
Get yourself either 4' or 6' white melamine 3/4" shelf board from HD or Lowes.  Get the 16" wide one and rip 2 each 2" strips lengthwise.  Use tablesaw or straight edge with circular saw, it has to be straight cuts..  Screw and/or glue these to the underside like ribs to keep the top staight.  If you put them about an inch from either edge, you will have a good clamping edge for whatever.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Leester
« Reply #2 on: April 23, 2011, 07:44:05 PM »
I don't have the Tom Morris set up but this is what I made for my jig. It's particle board shelving that I painted, think it was a buck or two at Menards.
Leester
ama 830538
« Reply #3 on: April 23, 2011, 08:20:16 PM »
Here is my wing and fuse jig.
« Reply #4 on: April 23, 2011, 09:45:02 PM »
Kelly...In many cases, these wooden pieces are simply CA'd to a glass plate atop the workbench. After the fuselage or wing is done, the blocks are tapped with a blunt object and the CA gives up. The residue is scraped off with a single edged razor blade.
The key to Tom Morris wing structure/jigging is that the LE & TE are made up with a spline that sits in/on the block. This is usually done by laminating the LE & TE (and you could build your TE with hinge slots at the same time). The splines can be inside or outside of the wing outline. In the latter case, the splines would be trimmed off after removal from the jig. Both have some advantages. The external spline at the LE would allow sheeting a C-tube while on the jig. The internal spline provides a "shelf" to support/align the typical Tom Morris "strip ribs". You could have splines both inside and outside, and see how you like each setup.   8) Steve
Offline Dick Pacini
« Reply #5 on: April 23, 2011, 10:17:52 PM »
This was sent to me when I asked the same question.
AMA 62221
Offline Robert Schroeder
« Reply #6 on: April 24, 2011, 02:41:56 PM »
What Ty said.
I use a 2" piece of angle iron in the rear and one or two shorter pieces for the leading edge depending upon whether I'm making a straight or tapered leading edge.  The 2" is heavy enough to not need any help to keep from moving.  My long pieces are 5' long.
Bob
Bob from NWO:  If it ain't broke, fix it till it is!
AMA 15083
« Reply #7 on: April 24, 2011, 05:37:21 PM »
Thanks to everyone for all the great ideas. I hadn't thought about Steve's idea of CAing to glass. The wing jig will be fairly straight forward. The fuselage jig pieces require a slotted base to be adjustable. I have a 14" x 60" piece of commercial grade counter top that is 2 1/2 thick and hasn't warped in 15 years and should make a great base, but I haven't figured out how to cut slots in it. It may be better to do as Allan suggested and go with the 3/4" melamine. I could probably router slots in it.
Ty, thanks for the info about the booklet from Tom. I will certainly follow up on that.
Again, thanks to everyone for their input.
Offline Geoff Goodworth
« Reply #8 on: April 24, 2011, 06:18:44 PM »
How do you guys store your jigs when not in use to ensure that they do not bend or twist?
« Reply #9 on: April 26, 2011, 10:11:10 PM »
After everyone's great sugestions I coudn't let this rest until I passed on the information I got. I called Tom Morris to order the booklet that Ty suggested. While I had Tom on the phone I ask how he used his fuselage brackets. The answer was so simple that it is one of those things that makes you want to bang your head on the workbench.
Here is the Reader's Digest  version. Get the hard board like Allan suggested. Make a pattern from the top view of the plans. Take a piece of 1/8 balsa, plywood or etc. Draw the verticle line down the center of the 1/8 piece and the horizontal lines at the former locations. Use the pattern to cut the 1/8 piece, flipping it over to be sure it is accurate on both sides. Cut the 1/8 piece to make an exact template of the top view of the plans. Attach thw 1/8 template to the melamine/hardboard, centered & squared. Place the fuselage brackets at each side of the 1/8 template at the former locations and screw them to the board. Put the fuselage side pieces inside the brackets, put the engine crutch inside the fuselage side pieces and fit the formers inside for a tight fit. Basically build the fuselage inside the brackets on top of the template.
He went into more detail, but I think you will get the jest of it. He said you can make a perfect fuselage everytime for $15 for the brackets and a few bucks for the lumber.
« Reply #10 on: April 30, 2011, 08:02:36 AM »
Once you get his building tips book, you will find he has several ways of doing things.   I have a set of the original run of blocks he sold.   H^^
« Reply #11 on: April 30, 2011, 09:36:49 PM »
Well, I do like Steve (I think) said.  I have a 3/8th" piece of tempered glass on my table so I tack glue the wing jig blocks in place with CA.  No screws, takes a minute or two to set everything up, and it works as good as anything.  Don't even need plans if you draw a wing on the glass with a Sharpie.
I do have a Byron Barker fuselage jig and would now never use anything else for building fuselages.  A very large nuclear device might not even harm it......  my great great great great great grand children will have it and it will still be in perfect shape (if anyone is around and building model airplanes at that time in the future). ;D
Big Bear
