  • June 20, 2025, 04:35:01 PM
Author Topic: Wing Jig Kit by Brodak  (Read 1616 times)
Offline Rob Roberts
« on: August 09, 2009, 04:27:57 PM »
Has anyone tried the Wing Jig Kit by Brodak? Is it worth the money , can it be used on lots of different kits?
 http://store.sshobbies.com/wingjigkit.html  thanks for the help.
  Rob Roberts
Re: Wing Jig Kit by Brodak
« Reply #1 on: August 10, 2009, 09:55:31 AM »
Have one that is almost identical to that.  Same diminsions.  It is not big enough for a full blown stunt plane.  Most sport planes are in the 40 inch range.  34 inches is not big enough in my opinion.  DOC Holliday
Offline Balsa Butcher
  • High Desert Flier
« Reply #2 on: August 10, 2009, 11:58:24 AM »
This jig is designed to do one wing panel at a time - then join the two together on a flat surface (or set up with dihedral like the Brodak Spitfire).  This creates some challanges but is similar to the way free-flight wings have been made for years. I haven't tried it but I imagine that it would work fine using that technique. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #3 on: August 18, 2009, 10:17:00 AM »
I agree with Pete.  Using the jig to build one panel at the time, it should work excellent.
Mongo
« Reply #4 on: August 24, 2009, 08:53:33 PM »
they work OK - I built the Spitfire wing with the jig - it came out "relatively" straight - built in two halves and joined.   If you are building a straight wing, do both halves - then re-insert the rods back into the wing centres and join them - the will line up prefectly..........getting the rods out is easy as well- just twist and push them throught to one end and pull them out.
From what I hear, all Brodak kits will have the laser cut holes in the ribs for this jig in the future
