here is the photo of the plane in question.
I am a little confused as to what your wanting to do - the nose looks fine.
However - I can give you a little advice on how ive rebuilt models in the past that have crashed.
You want to create an internal wall for the exterior of the fuse to sit on, so you are buildin in essence a new internal side wall that will allow you to join old piece and new piece together. If you try to butt join it without this internal wall it will prove difficult.
build it up as per normal - make the adjustments as required for the modified nose - redoing the cowl, canopy ect.. Sand back 2 inchs into the old paintwork, reprime, re fill go through your normal finishing process and be careful when you clear that you only spray the parts that have been sanded.
Without more information as to what was wrong with the 1st fuse I cant give any more help. If you want to make it stronger you can carbon laminate the internal walls with 1 extra firewall, if you want to make it 1/2 longer just add it to the front and reapply the finish.
Whats wrong with it?
