  • June 03, 2024, 10:13:35 AM
Author Topic: Silkspan Issues  (Read 2851 times)
Offline Mike Foley
Silkspan Issues
« on: August 14, 2007, 04:04:40 PM »
  I understand their has been silkspan problems with some people recently. Anyone recommend who supplies the good stuff?  K&S, Brodak or Sig? Is their more
than one manufacturer of silkspan or is it all the same?
I understand Nitrate is popular for laying down the paper, how about shrinking over the wing bays. Nitrate or Butyrate?
Offline Leester
Re: Silkspan Issues
« Reply #1 on: August 14, 2007, 07:09:44 PM »
Nitrate is low shrink,  where Butyrate is high shrink. I prefer my open bays tight. Make sure if you use high shrink you do the bottom of one panel and then the top of the same panel, having them dry together to avoid warps,twists etc.
Leester
ama 830538
Re: Silkspan Issues
« Reply #2 on: August 14, 2007, 10:26:36 PM »
Mike,
I've had the best luck with Sig lately.
Offline Jim Oliver
Re: Silkspan Issues
« Reply #3 on: August 14, 2007, 10:34:25 PM »
Sig Nitrate Clear base, Sig Lite Coat Clear for the remainder.
Jim
Jim Oliver
AMA 18475
Re: Silkspan Issues
« Reply #4 on: August 15, 2007, 08:01:49 AM »
I have no clue (honestly) as to which silkspan is the best these days.  I am still using K&S since my guy does get that in his shop.
I use nitrate up to attaching the covering.  Sig Supercoat Clear (high shrink) on the open bays only, and Sig Lite Coat Clear (low shrink) from there on out.
Re: Silkspan Issues
« Reply #5 on: August 15, 2007, 08:49:39 AM »
Bill,
That's pretty much my process except that I use Certified or Randolphs. Low shrink (called non-taunting by these guys) on the airframe up to and including covering. Then high shrink on the open bays (one coat). Then non-taunting the rest of the way.
I did have some problems with K&S a couple of planes back. Simply didn't want to shrink up. I ordered up a bunch of Sig (mostly GM and SGM) and haven't had a problem since.
Re: Silkspan Issues
« Reply #6 on: August 15, 2007, 09:38:04 AM »
Hi Randy,
I forgot to mention that I used Randolph's "Tinted Non-Tautening" for all my nitrate.  Thanks for reminding me! ;D
Offline Patrick Rowan
Re: Silkspan Issues
« Reply #7 on: August 15, 2007, 10:48:25 PM »
I Like both the K&S & Sig silkspan. They work well for me. I have both in my shop today.
Dope? I use Brodak Butyrate clear & colors. The clear dose fine on sticking down silkspan for me. No nitrate.
Fly Stunt
75750
Poland, Ohio
Re: Silkspan Issues
« Reply #8 on: August 16, 2007, 08:43:19 AM »
Hi Patrick,
Being older than dirt, I have used nitrate for a long time.  But sometimes, I have used butyrate clear.
As to dopes.  Randolphs makes Brodaks, and I am guessing Sig, too.
I think there are only three companies actually still producing dope. (??) (??)
Offline Leester
Re: Silkspan Issues
« Reply #9 on: August 16, 2007, 01:32:37 PM »
I saw a thread somewhere where Mike Gretz said Randolph does not make Sig's dope.
Leester
ama 830538
Re: Silkspan Issues
« Reply #10 on: August 17, 2007, 07:19:01 AM »
Thanks, Lee.
I wonder who does?  (I'm pretty certain that Sig, themselves, do not have a paint factory)   Not being a smartalec, just curious!   AFAIK, there are something like three companies left that actually produce Nitrate and Butyrate dope.  And, IIRC, two of those companies are under the same *parent* company! ;D
It just intrigues me, since I am afraid that silkspan, or silk, and dope finishes are going to go the way of the dinosoar.
Re: Silkspan Issues
« Reply #11 on: August 17, 2007, 10:04:35 AM »
Mike Mike Mike,
you need to quit worrying about which is better and get that cardinal done man, only another 6 weeks of contest season left. Guess maybe I need to come over and sit on your porch till its done. Seriously, it was great to get some flying in with you last weekend.Starting to cool off so maybe we can hook up again soon.
Re: Silkspan Issues
« Reply #12 on: August 17, 2007, 02:28:31 PM »
I know Randolphs and Certified are like Porche and Volkswagen: they come out of different doors of the same factory. But the formulation is different. That's clear when using them.
What's the third?
Offline Ward Van Duzer
Re: Silkspan Issues
« Reply #13 on: August 18, 2007, 01:50:10 PM »
Some time ago someone (at Aircraft Spruce) told me that Randolph's bought Certified. Then Randolph's moved out of New Jersey(?) to California. Seems like a weird move to me for a chemical co...Was Certified located in Cal? Maybe they joined up as one factory. Or Jersey taxed them to death! Anyway Certified was considerably less expensive than Randolph, but now there is no more Certified? Anyone have a handle on this? I know I got skinned pretty badly on my last Qt. of Randolph yellow...
W.
Re: Silkspan Issues
« Reply #14 on: August 18, 2007, 04:06:33 PM »
W.
Ward,
Certified is still listed by Aircraft Spruce.  All paints have risen dramatically, but it appears that airplane dope has risen the least!
The last gallon of white base lacquer I bought from PPG was $46 and now it's over $140!
Offline Leester
Re: Silkspan Issues
« Reply #15 on: August 18, 2007, 05:43:08 PM »
Bill: I stand corrected it was Mike Pratt that stated Sig dope was not Randolph.
It was on SSW topic # 268344  item # 12 He didn't say whose though.
Leester
ama 830538
Re: Silkspan Issues
« Reply #16 on: August 21, 2007, 03:15:47 PM »
Polyfiber bought out Randolph Aircraft products. They used to produce the best butyrate colored dope you could buy. When they picked up the Randolph line it made no sense to sell both lines so they dropped the Polyfiber and now sell Randolph only. Any "mixing dealer" selling this dope can mix all the Randolph colors as well as the old Poly-fiber colors. For what it's worth, they can also mix colors in a nitrate base. Go to Polyfiber.com to find the dealers. I purchase all my nitrate clear, butyrate clear, thinners and colors in quarts from Tex-Air Parts in Fort Worth, TX.
Don
Re: Silkspan Issues
« Reply #17 on: August 22, 2007, 07:34:05 AM »
Hi Don,
I go through Aircraft Spruce, now.  I used to be able to get all my Randolph's from the local airport, but no longer!
I had a Randolph RED one time (about 1964) that actually had microfine GOLD dust in it!  You could see it in the bottom of the glass jar when it had been sitting.  It was the prettiest red I have ever used.
Online Howard Rush
Re: Silkspan Issues
« Reply #18 on: September 12, 2007, 10:36:17 PM »
I recently got a bunch of Sig silkspan.  It seems to be the good old stuff.
