  • July 08, 2025, 03:53:53 AM
Author Topic: S.T.51 on an A.R.F. tutor  (Read 1341 times)
Offline steve pagano
« on: August 01, 2007, 07:53:35 PM »
I tried to mount my 51 on the tutor and when drilling out the mounts, I did it a little to close to the edge and split the mount HB~> HB~> Any suggestions? Can i go ahead and just mount the engine anyway? and also which is better for the 51 mounts? 4-40's or 6-32's?(i was drilling out the mount to put in 6-32nd blind nuts)
Success isn't a destination.It's a journey!!!!!
A.M.A. 820-823
Re: S.T.51 on an A.R.F. tutor
« Reply #1 on: August 01, 2007, 08:42:15 PM »
6-32's are a bit of overkill with the 51 on the Tutur II.  The fuselage will fail before 4-40's do.  Also some versions of the G51 have the casting on the case that won't clear the head on 6-32 bolts.  I used 4-40's on mine and haven't had a problem.  Depending on how bad the holes broke thru, I'd probably just epoxy a layer of 1/32 ply across the open side of the mounts.
Offline Bootlegger
« Reply #2 on: August 02, 2007, 02:41:26 PM »
 Might try some wooden dowels in the hole(s) that split. I have done this and glued them in with Aliphetic resin (Titebond) and they worked well...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Jim Oliver
« Reply #3 on: August 02, 2007, 04:56:04 PM »
Hardwood dowels where the bolts go thru are a good idea anyway--most of the ARF's have very soft engine mount wood.
Jim
Jim Oliver
AMA 18475
« Reply #4 on: August 04, 2007, 11:22:08 PM »
Fill the odd bit , with ayrldite .and leave it for a week .
