  • June 20, 2025, 03:01:18 AM
Author Topic: Tank Setting ?  (Read 959 times)
Offline Terry Bolin
  • Havin' the time of our lives!
Tank Setting ?
« on: February 15, 2010, 02:27:32 PM »
I am finishing up a Full body Stearman and have a few thoughts on how to make the tank adjustable without a hatch on the bottom of the fus but what have you guys seen done that was successful and do you have pictures?  I would rather not have to have a hatch but can if I must.  I am using a 4.5 oz tank on a OS 46. Thanks for your two cents. Does this belong in "Open" instead of building Tech?
Thanks, Terry
Re: Tank Setting ?
« Reply #1 on: February 15, 2010, 08:19:49 PM »
What OS .46? Upright, inverted or sidemounted? Uniflow or not? If it's an inverted .46LA and uniflow, I may have an answer for you. Otherwise, not.  :-\ Steve
Offline Kim Mortimore
Re: Tank Setting ?
« Reply #2 on: February 16, 2010, 12:31:55 PM »
Terry,
Also, is the engine beam-mounted, or are you using an R/C type radial mount?
Kim Mortimore
Kim Mortimore
Santa Clara, CA
Offline Terry Bolin
Re: Tank Setting ?
« Reply #3 on: February 16, 2010, 09:53:15 PM »
Sorry, I didn't think about posting that info too. I will be using a RC Round mount, OS 46 CL side mounted . Let me know what else you may need. Thanks! Terry
Offline Terry Bolin
Re: Tank Setting ?
« Reply #4 on: February 19, 2010, 07:10:10 AM »
Got it, I came up with an external adjustment using a nylon wing bolt. Thanks, T
