  • July 13, 2025, 12:18:17 PM
Author Topic: Rounding the last turn (Pic)  (Read 2582 times)
Online RC Storick
« on: January 15, 2014, 06:05:02 PM »
I am in the home stretch now. All framed up and on the gear. First thing is clean the shop and then start detail sanding. Should start the finish this weekend.
Re: Rounding the last turn (Pic)
« Reply #1 on: January 15, 2014, 07:11:26 PM »
I am in the home stretch now.  Should start the finish this weekend.
The finish  starts with the first piece of wood cut  .........       y1 y1 y1 #^ #^ #^
Online RC Storick
« Reply #2 on: January 15, 2014, 07:18:31 PM »
Yah but The forum is like sand you have to sift out the cat turds to get to the bone.
« Reply #3 on: January 15, 2014, 07:58:11 PM »
 Jeez, I can't believe this is taking so long. :##
Offline Doug Moon
« Reply #4 on: January 16, 2014, 07:50:00 AM »
That's a cool plane.  It looks fast just sitting there.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline Allan Perret
  • Proverbs
« Reply #5 on: January 16, 2014, 08:13:16 AM »
Nice.
Can you take some close ups of those hinges installed at this stage.. <=
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #6 on: January 16, 2014, 09:41:40 AM »
Sparky, I like it.  It has a kind of classic look to it.
Offline MarcusCordeiro
« Reply #7 on: January 16, 2014, 10:28:58 AM »
The woodwork is so good it doesn't look like it needs sanding!!
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline Dan Bregar
  • Field Marshall
« Reply #8 on: January 16, 2014, 06:10:09 PM »
Robert you do good work, and LOTS of it !  By the time the week-end gets here, it will be time for you to start on your next build.  LL~ Heck you can probably build 2 or 3 more before nice flying weather arrives !   LL~  Man you are a prolific builder if there ever was one.  Cut it out Robert, you are making the rest of us look bad.;  LL~
AMA 33676
« Reply #9 on: January 17, 2014, 08:37:07 AM »
I think he is trying to beat Jack Sheeks on the number of builds.   I would still like to see a set of plans for the original Viper.
Offline Crist Rigotti
« Reply #10 on: January 17, 2014, 06:26:23 PM »
Looks nice Sparky!
Online RC Storick
« Reply #11 on: January 18, 2014, 12:00:41 PM »
I am sanding everything with 400 and finding any bad spots right now. Not much to see. I will probably put 2 coats of clear on today. and sand with 600 then cover. This is the lightest ,straightest airplane of this size I have built to date. Airframe is 20 ounces with fillets no covering. The hinge's were a vast improvement over the flat hinges. Zero gap, No way to tape these because if you did they wouldn't move. I will post a pic when there is something to see.
Offline Gerald Arana
« Reply #12 on: January 18, 2014, 04:34:57 PM »
Robert;
What you're not flying it yet?????? Just kidding. You have to be the fastest builder I know about. Hey PTG, he's got you beaten! LL~ LL~
Seriously, I like the hinging method you have chosen and am interested to know how it turns out. (No pun intended) We (I) used to do a similar hinge on our racing gliders (RC) for minimum drag. I believe it was called a "Knuckle" hinge.
When I glued mine together I used two layers (Next to the hinge) of masking tape for the gap. Any closed and there was a chance of a bind, not good.
Cheers, Jerry
