  • July 06, 2025, 07:52:18 AM
Author Topic: removing monokote from monokote  (Read 1138 times)
Offline John KruziK
« on: December 14, 2007, 06:20:40 PM »
I need to know how to remove a monokote design that was placed on top of monokote finished wing. looks bad and heat doesn't seen to help. any suggestions? John
AMA 874027
Offline Jim Oliver
Re: removing monokote from monokote
« Reply #1 on: December 14, 2007, 07:02:47 PM »
Acetone carefully applied to edges of trim to dissolve the adhesive, lift the edge of the trim as the adhesive softens.  Clean up the mess with acetone dampened rag or paper towel.
If you don't know anything about acetone----it is very flammable and it's not good for the body.
Have lots of fun!!
Jim
Jim Oliver
AMA 18475
Alan Hahn
« Reply #2 on: December 15, 2007, 01:43:20 PM »
If it really is Monocote, it may be darn near impossible. If it is Ultracote, then heat will allow you separate the two (at least when you first put it on, it was one of the "features"--I am not sure about long term. Other covering materials may be like Ultracote.
