  • June 13, 2025, 04:37:37 AM
Author Topic: Stiffness of carbon viel versus glasscloth  (Read 1853 times)
Offline dynasoar1948
« on: October 10, 2010, 09:47:08 AM »
Gentlemen,
I'm looking for inputs relative to the increase in stiffness of the two thicknesses of carbon fiber veil versus 3/4 Oz fibreglas.  Typical 1/4 inch balsa stab or flap, with material bedded in epoxy.  Does the increase in rigidity of the veil approach glass?
Thanks,  Will Stewart
William Stewart
Offline Greg L Bahrman
Re: Stiffness of carbon viel versus glasscloth
« Reply #1 on: October 10, 2010, 11:51:51 AM »
Kind of hard to answer your question unless one has done exactly as you say and compared the two......I have never done the 2 layers of veil but I have done both one layer of med. silkspan on a set of flaps and one layer of .2 oz. veil on another set of flaps both attached with nitrate dope. I find that they are very close in strength. I recently did flaps on a 51 inch wingspan, 1/4 in. thk. with Z-Poxy (finishing resin) and .5 oz. fiberglass cloth and it was far and away stronger than either of the previous methods. Hope this is helpful....
Greg Bahrman, AMA 312522
Simi Valley, Ca.
« Reply #2 on: October 10, 2010, 12:24:23 PM »
"Strength" is an imprecise term, and usually means "breaking strength", i.e. the amount that you can load the part before it fractures.  I think you mean "stiffness", i.e. the amount that the part will deflect for a given load.
Carbon fiber is renowned for having a way high modulus of stiffness, meaning the highest stiffness per unit volume, and it's lighter than glass.  So I think if you used the same amount of carbon, weight for weight, as glass, then you would find that you had a stiffer part.  Your binder (dope, epoxy, whatever) would have to be up to the task of holding things together.
None of which answers the question -- if some intrepid modeler out there were to take a number of different combinations of glass, carbon and maybe kevlar*, and dope, epoxy and maybe polyester, and experimented with making the lightest possible structure out of them with a balsa or foam core (vacuum bag?), then we could have enough apples-apples comparisons to actually make engineering decisions.
Until then, just build what floats your boat.
* probably not -- kevlar gives toughness, but not, to my knowledge, stiffness.
« Reply #3 on: October 10, 2010, 12:33:33 PM »
It is not the material that makes for stiffness in my thinking.  Backin the day when trying to make fibre glas fuselages, we tried different glas cloth thicknesses.  The resins were polyester and eposly.  Only choice we had then.  Epoxy made for the stiffness.   Polyester was very pliable.  We learned that using a fibre glas mat cut ito squares flaking off thin layers made for some strong landing gear mounts in the fuse shells.  We also learned that using slo cure epoxy also made for light parts as the roll of toilet tissue was used to daub out the excess epoxy.  The resin with any of the carbon cloth or glas is what makes the stiffness.
« Reply #4 on: October 10, 2010, 09:41:04 PM »
Tim-
I did some of what you suggested a number of years ago testing light carbon matte against silkspan. Made a series of samples from the same sheet of 1/8 balsa covered on both sides with the test material using dope for adhesive. Tested them for flex by hanging weight on the cantilevered samples, for torsion by twisting them, and finally breakage by supporting both ends and loading the middle to failure. Final results? the carbon mattte and the silkspan were a dead heat, differences were very small. going either way in many cases. results were published in Stunt News a long time ago. My conclusion is that the big advantage to the matte is that it does not shrink up between the ribs on wing leading edges so no more hungry dog wings!
Don
Offline John Sunderland
« Reply #5 on: October 10, 2010, 10:52:52 PM »
 I purposely built a profile fuse from punk light 1/2" balsa...rare I know in that thickness but I found one. I covered it in CF veil and finish cure epoxy..one to apply, one final and sanded well in between and after. Straight to color dope for finish and If i had clear coated it would have been perfect. It lasted 9 years of fairly heavy use and is still the lightest and strongest I ever built. Im getting ready to do it again except this time it will be for an entire built up and sheeted foam structure. I like it this way but hate applying it with dope...not enough stiffness  and doesnt stick as well. Sands to almost gone and unless you silkspan over it loses the strength. With epoxy it fills well but does not lose much of its original intended purpose to the sand block. Worked before over the years for me and it is definitely lighter than glass.
« Reply #6 on: October 12, 2010, 09:14:56 AM »
The best combination is epoxy and carbon fiber.  The matrix(epoxy) is as important as the base, glass or carbon.  You don't want a soft, glue epoxy, but a hard, finishing resin. Ideally the epoxy and base should be about equal in volume.  When you pack round fibers into a matte about half the volume is air, so completely filling that space is the best you can hope to do.  Any more and the piece is thicker and heavier than it needs to be.
Using something soft, like dope, for the matrix defeats the whole purpose.  The base has to be held solidly in place so their greater strength can be put to use.  Any kind of dope is simply too soft and flexible to keep the fibers of the base in place to add to the strength.  Which is why dope applied carbon fiber was no stiffer than silkspan.
Offline Kim Mortimore
« Reply #7 on: October 14, 2010, 05:05:14 PM »
John, Phil,
Could one of you describe your method for applying the CF with epoxy?
Kim Mortimore
Santa Clara, CA
Offline Alan Resinger
« Reply #8 on: October 15, 2010, 07:36:21 AM »
I recently did some 1/4" sheet flaps that had been properly sanded down to 400 grit.  After a good clearning I applied .5 oz carbon mat using z-poxy finishing resin.  The flaps where then put in a vacuum bag with release fabric and breather cloth.  I did both sides at the same time.  After curing the flaps were ready for finish after a good sanding with 320 and then 400 grit Norton A275 paper.  Very stiff and good in torsion.
Offline Warren Wagner
  • Bradenton, FL
« Reply #9 on: October 15, 2010, 03:14:31 PM »
Alan,
Could you please briefly describe what your vacuum bagging equipment consists of.   I'm familiar with the basic process, but it sounds like a rather large commitment to invest in.  If you could post a photo of your setup, it would be helpful.
Question:  How are the EDGES of the flaps handled in the vacuum bagging process?
TIA
Cheers.
Warren Wagner
Warren Wagner
AMA 1385
« Reply #10 on: October 15, 2010, 09:02:42 PM »
John, Phil,
Best is vacuum bagging.  If you can't or don't want to spend the money, get some 4 mill builders plastic.  Cut a piece a couple inches oversize for the piece you are coating.  Lay the plastic out flat and spread a measured amount of epoxy.  Lay the graphite on top and mop up all the excess epoxy.  Block the flap up off the building board 4-3 inches on a solid piece of wood cut smaller than the flap.  Lay the plastic/graphite in place.  Hang weight along the plastic front and rear to pull it down tight.  Fishing sinkers on bull dog paper clips work.  While the glue is still wet slide things around and pull on the plastic to eliminate any wrinkles and make sure the graphite is where you want it.
Working carefully, you can trap the graphite/epoxy under iron on film.  Attach the film on the bottom of the leading edge.  Wet the graphite and mop up any excess and lay it on top of the flap. Wrap the covering around and pull it snug at the trailing edge and iron it down on the side opposite the graphite.  Then shrink the covering down smoothly to eliminate any wrinkles.  Repeat for the other side.  You have to be careful not to get any epoxy on the areas where the covering is going to be ironed down.  It keeps the covering from adhering.
« Reply #11 on: October 15, 2010, 10:23:26 PM »
Phil,
I appreciate the detailed description.  So this technique if for flaps or other relatively thin pieces that can be secured flat during the application of the matte?  How about built-up fuselages?  Would you need to process each piece before assembly, or would that leave the sides, for example, too rigid to pull together at the tail?
Kim Mortimore
Santa Clara, CA
« Reply #12 on: October 15, 2010, 11:13:58 PM »
 ;D I cant give you a single detail better than Phil. I would point out that it is important to properly block up, jig up and or support any tapered TE flying surfaces before allowing epoxy to cure, bagged or brushed, weighted or otherwise. You will have crooked surfaces for sure that no amount of steam and hot ironing is going to fix. Point is to make sure you have this base covered before mixing any resin. Not to seem redundant but it is an important consideration. %^@
« Reply #13 on: October 19, 2010, 07:53:33 AM »
Warren,
Vacuum bagging parts can be done pretty cheaply.  Aerospace Composites sells a small vacuum unit that consists of a diaphram pump that is designed to run continueously during the bagging operation.  The whole kit sells for about $140.  It includes the pump, bagging film, breather cloth, release ply and mylar for other types of bagging operation.  I got mine from someone who got it and never used it.  Works like a charm.
Alan
« Reply #14 on: October 19, 2010, 05:44:00 PM »
Phil,
Phil,
Fuselages really only need a strip down the sides.  If you want to cover the whole thing you need to find some soft, compliant veil and use thinner plastic so it can stretch and conform to the shape.  I don't see why you couldn't apply the veil to the sides prior to cutting them out.  It will still stiffen the structure.
steven yampolsky
« Reply #15 on: October 21, 2010, 08:06:51 AM »
Stiffness is only good in the areas where it is needed. Any kind of stiffening near the tips are of no use and to some degree detrimental to model's performance(read extra weight). If one were to measure surface tension of a stab, he would find that majority of force is centered near the middle. The tips experience almost zero surface tension. With that in mind, may I suggest looking stiffenning the middle third of the stab. Why middle third? Middle third covers enough of the span to provide more than adequate stiffness. In reality you need a lot less area since balsa near the surface soaked in dope provides a lot of tension resistance plus silkspan(the lightest one) also increases the stiffness a LOT.
There are many ways to increase stiffness and I'll start with the simplest ones:
1) apply extra layer of silkspan on both sides of the stab near the middle third. Use thinned dope for the first layer or two to allow it to soak into the wood.
2) Glue 1/65th birch plywood to cover the middle third. Keep it 1/4 from the leading edge to help with feathering it into the stab. some people sand the feather but I just apply light filler.
3) get a strip of .005 thick 1" wide carbon fiber laminate(http://www.cstsales.com/carbon_Laminates_36.html) and glue it on both sides of of the stab with CA. Position it anywhere on the stab. Personally, I like it right up against the trailing edge so that I only have to use filler on one side when feathering. This is my preferred method.
I am not sold on using carbon veil on stabs. Carbon veil is good for providing stiffness against twisting forces such those applied to flaps and fuselage in flight. It will do a fine job on a stab as well(if applied BEFORE the stab is glued into the fuse) but it is not designed to provide directional rigidity which is exactly the kind forces are acting on a stab in flight.
