  • July 08, 2025, 07:23:30 AM
Author Topic: Pocket hinges  (Read 2033 times)
Offline Mike Quinn
Pocket hinges
« on: November 04, 2020, 03:36:54 PM »
Hi
Can anyone post details of how to make pocket hinges and also the pockets for where the flap horns fit.  Is it best to glue the horns in or just free fit so to speak?
Cheers
Re: Pocket hinges
« Reply #1 on: November 04, 2020, 06:17:16 PM »
Hi
Cheers
I will address the 2nd question - never glue the horns.  A lot of folks use a bass or plywood plug with a tight fit hole.  I use brass or aluminum tube glued in.
Several reasons.  If glued the alignment must be perfectly centered or they will bind.  Second is removal.  If you glue them you can't remove the flaps without breaking the joint.
Offline Crist Rigotti
Re: Pocket hinges
« Reply #2 on: November 04, 2020, 08:44:31 PM »
Re: Pocket hinges
« Reply #3 on: November 04, 2020, 08:46:44 PM »
Offline Mike Quinn
Re: Pocket hinges
« Reply #4 on: November 04, 2020, 11:53:11 PM »
Hello
Thanks ... will check out the build logs.  Makes sense re the gluing.
Cheers
