  • June 17, 2025, 04:23:58 AM
Author Topic: Where to get Polyspan ?  (Read 1541 times)
Offline Rob Killick
« on: May 02, 2009, 03:17:52 PM »
Hi ,
I was wondering where I can get some Polyspan and Ployspan Lite (or is it Ultra) ?
Thanks in advance ,
Rob Killick
« Last Edit: May 02, 2009, 03:39:11 PM by Rob Killick »
Rob Killick , MAAC 33300
Re: Where to get Polyspan ?
« Reply #1 on: May 02, 2009, 04:52:37 PM »
Polyspan can be obtained from Controline Central (there should be an ad banner on Stunthanger)http://www.clcentral.com/products.asp?cat=46&pg=3
Not sure what the other request is...if you want Plyspan, it is a two layered tissue (as near as I can tell), sorta like Japanese Tissue...I'm not fond of it, but I believe SIG has it. FWIW, I'd just get CF mat from CST to use on the fuselage and solid wood areas, to avoid the shrinking/warping problems of silkspan.  D>K Steve
Offline Rob Killick
« Reply #2 on: May 02, 2009, 07:58:33 PM »
Thanks for the info , gentlemen ...
I'll give CLC a try (methinks they're in the middle of a move , though)
Rob Killick
Offline dennis lipsett
« Reply #3 on: May 02, 2009, 08:08:02 PM »
Hi ,
Thanks in advance ,
Rob Killick
Go to:
www,modelresearchlabs.com.
They have Polyspan in decent sizes for the money and who knows you just might find some other neat stuff that you gotta have. They have a tutorial on the use of the stuff also.
dennis
Online Lauri Malila
« Reply #4 on: May 03, 2009, 05:47:38 AM »
 Hi.
 At least in Europe Polyspan (or Salzer paper) is available is 3 thicknesses. The heavies one is not  good as the structure is not homogenic: it has longitudal bundles of fibers in it every few cm. Medium is best for everything. I don't recommend using the lightest, it needs much more dope to seal it properly and is also quite fragile I've used it in wing tip panels of my F1A's but won't use anymore. Weight difference between Medium and lw is minimal.
 I buy mine from Mike Woodhouse's Free Flight supplies in UK.
 L
Offline Rob Killick
« Reply #5 on: May 03, 2009, 03:17:45 PM »
Dennis and Lauri ,
Thanks for the info  y1
Rob Killick
