  • August 01, 2025, 09:04:53 AM
Author Topic: Nobler oops  (Read 3636 times)
Offline Mike Spiess
  • bikemike
  • AMA #4060
Nobler oops
« on: July 04, 2006, 07:08:20 PM »
I hve a Nobler built and has 4 flights. I used the included control rods. Now what should I do.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Offline Leester
Re: Nobler oops
« Reply #1 on: July 04, 2006, 07:49:55 PM »
You either take it apart and replace them or continue to fly it, not much more you can do.
Leester
ama 830538
Alan Hahn
Re: Nobler oops
« Reply #2 on: July 04, 2006, 08:38:46 PM »
I  assume you mean the Top FLite Nobler Arf?
If so, then at a minimum, take off the canopy, and flood the clevises on the flap horns with Locktite 242 (the blue stuff). this will help. I can't remember if the elevator horn is soldered or not, and I am too lazy to look. So if it is also threaded, cut into the monocote near the tail and use the same locktite.
I found that the locktite really held my clevises on the stock Arf Nobler. I eventually replaced the clevises with ball links (that was a pain!) on the Arf Nobler, but I found it the locktite was really holding pretty good.
Offline Tom Dugan
Re: Nobler oops
« Reply #3 on: July 05, 2006, 06:30:43 AM »
Except for another Ukey, I probably will not buy another ARF kit.  It was to much trouble to replace the controls in the ARF Cardinal I have.  I ultimately had to recover the wing and figure that if I have to go to this extent then why not just build.
Im curious why the major vendors dont change the control systems to something worthwhile???
Thomas
Offline old fart
  • ACE
Re: Nobler oops
« Reply #4 on: July 05, 2006, 06:38:35 AM »
$$$$$$$$$$$$$$$$$$$$$$$ **)Or we still don't speak chineese very well :!
RON SMITH
Offline Tom Dugan
Re: Nobler oops
« Reply #5 on: July 06, 2006, 12:43:18 PM »
I didnt know the Teosawki was an ARF...Who sells them?
Re: Nobler oops
« Reply #6 on: July 06, 2006, 01:46:22 PM »
Clayton Smith from here in NC makes them, when he makes them!  **)
Greensboro or W-S.
Bill <><
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: Nobler oops
« Reply #7 on: July 06, 2006, 02:42:48 PM »
Thanks guys I'll use the locktite trick. The way I fly it may not last more than eight more flights. I'm kinda on my own building and flying here as the closest CL club is about 100mi away. I get there when I can but my schedule is real tight now so I kinda plod along. It's been great to find this web site to help.
St Peter MN
Offline mark eisenhut
    • madphotos.net
Re: Nobler oops
« Reply #8 on: September 21, 2006, 08:44:38 AM »
whats wrong with the control rods and arf nobler kit? i was thinking of getting one someday.
thanks for any info
mark eisenhut
mark eisenhut
Offline Ron Merrill
Re: Nobler oops
« Reply #9 on: September 21, 2006, 09:02:35 AM »
WE need to petition Brodak, i think he might listen, to sell ARF's with better controls and the bring the building of his kits back here. I know the price would increase,  bulletproof is woth something. Just me. y1 <= #^. Ron.
Offline Ironbomb
Re: Nobler oops
« Reply #10 on: September 21, 2006, 09:34:05 AM »
Mike, the control hardware in the Top Flight kit is weak. Basicly, the bellcrank, and clevises are the weak links. I was able to pull the hinge pin out of a clevis with almost no effort with a pair of needlenose pliers. I also replaced the bellcrank and leadouts, at the strong suggestions from other that learned the hard way. If I remember correctly, the leadout cable was sawing thru the bellcrank on some airplnes, and I think the crimps were causing some headache as well.
Flying Models magazine (dont remember the issue) had a good article on all the Nobler improvments that were being done, and there should be lots more others can tell when they read your post.
I am useing stock control horns, and pushrods on mine. Sullivan clevises and leadouts on a Sig 3"bellcrank are the only replacments I made to my Nobler. It flew great until the wind did me in.
Good luck with your Nobler,
Greg
Beating the crap out of the ground, one airplane at a time
Greg Bossio
AMA 834382
Offline Jim Oliver
Re: Nobler oops
« Reply #11 on: September 21, 2006, 02:59:32 PM »
Recent production of Brodak's Cardinal ARF and Pathfinder ARF have had a metal clevis
soldered on the end of the bellcrank to flap pushrod.  A nasty looking job, too.
I just cut the pushrod off a little and use a solder-on split coupler to get a 90* bend in exactly the right place.
Rebuilding the control systems should be S.O.P. for any of the ARF's I have worked on, Brodak or Top Flite.
Jim
Jim Oliver
AMA 18475
Re: Nobler oops
« Reply #12 on: September 21, 2006, 05:53:19 PM »
thanks for any info
mark eisenhut
Hi Mark,
Unfortunately, the stock Nobler ARF control system is not very good at all if you want reliability.  It *might* last the lifetime of the plane......... it *might* shorten the lifetime fo the plane (like after 4-12 flights).
The clevices are not good.  Best to just put in a nylon BC, some wrapped or solid LOs, and new pushrods.  Just replacing them with normal parts and wire will bring it up to standards of the '60s.  Tom Morris makes a drop in ball link control system for the TF Nobler ARF, but at about $40 it is a *little* pricey.  I bought them and will use them in a plans built Nobler (Louis Grondal AMA Special. 1960 and 1962 World Champion).
Bill <><
    • madphotos.net
Re: Nobler oops
« Reply #13 on: September 21, 2006, 08:17:17 PM »
so do all the arf kits have this problem tf and brodaks
thank you
 mark eisenhut
mark eisenhut
Offline Greg L Bahrman
Re: Nobler oops
« Reply #14 on: September 21, 2006, 08:51:14 PM »
thank you
 mark eisenhut
YES
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Re: Nobler oops
« Reply #15 on: September 21, 2006, 09:36:11 PM »
I am not sure about the Force from Sig...............
But all the others can really benefit from simple updating of the control system, if for nothing else, peace of mind!  I really don't want to be concerned that a lead out will break, the bellcrank will fail, the clevis will break or come off the rod, etc., etc..   If I am going to tear up a plane, I want to be the factor that causes its demise! :)
Bill <><
