  • June 15, 2025, 10:02:11 PM
Author Topic: Pipe tunnel  (Read 913 times)
Online James Mills
Pipe tunnel
« on: July 21, 2009, 10:54:21 PM »
How much of the pipe needs to be covered in the pipe tunnel (any pictures)?
James
AMA 491167
Re: Pipe tunnel
« Reply #1 on: July 22, 2009, 08:06:02 AM »
I have seen planes with the pipe just out of sight when viewed from the side.  It depends on how deep the fuse is in reality.  As stated on another thread you can mold sheet balsa or carve a block to cover it.  Remember there has to be air flow over it to keep it cool.  Back where the stub comes down make the opening a little bigger area wise than the area around the pipe itself.  DOC Holliday
