  • June 20, 2025, 01:00:55 AM
Author Topic: Pictures of Modified Forerunner  (Read 3061 times)
Mike Griffin
« on: February 03, 2008, 03:21:03 PM »
After several months of work and a couple of suicidal thoughts (just kidding) the modified Forerunner is finished. All I need to do now is mount the tank, the .46 engine and finish the leadouts. Don't make fun of the white tailwheel, I am changing it. This is a modified version of Tom Farmer's Forerunner. The main change I made was the wing. It is built up instead of foam. I also increased the size of the tail feathers a little. The plane is covered in polyspan and the paint is Rustoleum. Hope you guys enjoy the pictures.
Offline David Miller
  • CL, RC, Hunting and Fishing!
Re: Pictures of Modified Forerunner
« Reply #1 on: February 03, 2008, 08:15:20 PM »
Mike, which .46 are you putting in it? It really looks nice. I always get off on the ol red white and blue.
MSgt (RET) David G. Miller
AMA 560263
Mike Griffin
« Reply #2 on: February 04, 2008, 08:21:11 AM »
Hi David,
I have a OS .46 LA I am going to put in it.  I have had real good luck with these engines and I hope it will work well in this bird.
Offline joe renfro
« Reply #3 on: February 07, 2008, 11:28:11 AM »
Very nice indeed..! Question...Is the Rustoleum overpainted with a clear or a fuel-proofer? And which Rustoleum did you use..there are several varieties..
Once again..very nice..
Mike Griffin
« Reply #4 on: February 07, 2008, 08:42:57 PM »
Joe,
I used the Rustoleum enamel in the spray can right off of Lowe's shelf.  I used Rustoleum Crystal Clear enamel as the final coat to add the shine.
Offline joe renfro
« Reply #5 on: February 07, 2008, 10:03:18 PM »
Have you used this process before?...Does the Rustoleum Clear do a good job of fuel-proofing?  I keep getting mixed reports on this...Will be good to hear if you have had good results from this....
Thx..joe
Offline Joseph Patterson
  • AMA member- Supporter
« Reply #6 on: November 19, 2010, 09:36:22 PM »
My experience with Rustaleum spray can paint is good. In itself it is fuel proof.
Offline Russell Shaffer
« Reply #7 on: November 19, 2010, 10:23:39 PM »
Very nice.  I don't see a problem with the tail wheel, myself.
Russell Shaffer
Klamath Falls, Oregon
Offline dennis lipsett
« Reply #8 on: November 20, 2010, 06:09:29 AM »
The clear is NOT fuelproof
Offline Joe Mig
« Reply #9 on: November 20, 2010, 06:50:59 AM »
Nice job,  If the tail wheel is rubber not foam, all you have to do is put it in a small cup of acetone and wipe it off.
« Reply #10 on: November 20, 2010, 03:34:36 PM »
Not feeling the wing mounted gear on a profile. Profiles tend to live hard lives,(late nights, hanging out in bars etc.) Fuselage mounted gear just tends to hold up better here.
Offline Kim Mortimore
« Reply #11 on: November 20, 2010, 07:44:25 PM »
Mike,
Did you use Rustoleum enamel on the open wing bays over the polyspan?  Any primer or clear dope underneath the Rusto?
Thanks.
Kim Mortimore
Santa Clara, CA
« Reply #12 on: November 20, 2010, 08:25:21 PM »
Cool paint scheme.
Offline Douglas Ames
« Reply #13 on: November 20, 2010, 10:42:28 PM »
AMA 656546
Offline Posthole_digger
« Reply #14 on: November 21, 2010, 02:38:40 AM »
You need to do something. As already stated - the clear is not fuelproof.
After all, model aviation is not a matter of life or death - its more important than that!
« Reply #15 on: November 27, 2010, 11:03:54 AM »
How long do you guys let the clear cure before flying?   I have so far had no problems with clear after it sits for a couple of weeks.  Now, even my two part auto clear has to sit for a week or two.   H^^
