  • June 19, 2025, 01:48:13 PM
Author Topic: SV 11 Build Start date 9-30-2012 update  (Read 5380 times)
Offline RC Storick
« on: October 25, 2012, 08:41:27 PM »
Its together and I will post more later.
Re: SV 11 Build Start date 9-30-2012 update
« Reply #1 on: October 25, 2012, 08:51:26 PM »
How much fiberglass did you put on the wing center, what weight fiberglass, what weave orientation, and can I assume epoxy matrix? It looks like it's maybe 5"-6" wide?  H^^ Steve
Offline RC Storick
« Reply #2 on: October 25, 2012, 09:07:08 PM »
1 layer of 3 inch wide 1 OZ cloth and covered by a ellipse of 1/2 cloth. I used z-poxy
« Reply #3 on: October 25, 2012, 10:26:07 PM »
 Looking great! Hoping for a detailed step by step on your finishing process!
« Reply #4 on: October 26, 2012, 04:48:03 AM »
Looks good Spark
Derek
Offline MarcusCordeiro
« Reply #5 on: October 27, 2012, 03:46:38 AM »
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
« Reply #6 on: October 31, 2012, 09:47:37 PM »
 It's been almost a week since we've heard from you here Sparky, I suppose you're about ready for paint by now... S?P :)
Offline RC Storick
« Reply #7 on: November 05, 2012, 06:40:26 AM »
2 shots of it framed up
« Reply #8 on: November 05, 2012, 06:53:58 AM »
Nice bird!
Did you change the fin/rudder design?
What are you planning to use for finishing, assuming you will paint it?
Marcus
Aces High!
Offline RC Storick
« Reply #9 on: November 05, 2012, 07:53:49 AM »
The rudder is the only change (same size). I had it laying around and it was light. I will be using dope as I always do. Now I can co back to work on my TOP Secret Electric ship. Come NATS time I will have 6 ships to choose from. More than likely it will be one of the new ones.
« Reply #10 on: November 05, 2012, 11:05:14 AM »
 Lookin' good! This is still a fast build. y1
« Reply #11 on: November 05, 2012, 12:11:58 PM »
I like it Sparky. Good looking rudder shape.
D
Offline RC Storick
« Reply #12 on: November 05, 2012, 05:42:39 PM »
I have forgotten how much work it is to finish a plane. So I went to the hardware store and bought the thing that makes my finishes look the way they do in a can. Should make it faster.
Offline John Hammonds
« Reply #13 on: November 06, 2012, 04:48:35 AM »
Elbow grease, A rare find indeed.
I finally found one of these the other day so hopefully If I can find some elbow grease as well I can get my winter projects moving.
TTFN
John.
BMFA 165249
« Reply #14 on: November 15, 2012, 09:27:39 PM »
 What's the latest Sparky?
Offline RC Storick
« Reply #15 on: November 15, 2012, 11:08:08 PM »
Still sanding takes a lot of sanding to get a slick finish. I'll post pics as soon as I start to paint.
Offline Steve Fitton
« Reply #16 on: November 16, 2012, 02:05:07 PM »
If you use Derek's sekrit Ragu primer you don't need to do much sanding first! n~
Offline Brad Smith
« Reply #17 on: November 16, 2012, 06:11:28 PM »
Are your hinges glued, in the pic you showed?
Brad smith AMA780054
Offline John Sunderland
« Reply #18 on: November 16, 2012, 08:01:41 PM »
I like it too! Kind of familiar! ;D
D
Offline RC Storick
« Reply #19 on: November 17, 2012, 06:04:31 PM »
The hinges are the last step in the finish. Very last.
« Reply #20 on: November 26, 2012, 09:27:11 PM »
 Still sanding? ;D
« Reply #21 on: December 07, 2012, 09:41:45 PM »
 Ok Sparky, I see in the other post the T-shirts are all shipped. So now, what's up with the SV? S?P ;D
« Reply #22 on: December 18, 2012, 09:16:26 PM »
Still sanding? ;D
Yes  and methinks  his camera is broken !!   LL~ LL~ LL~ LL~ LL~ LL~
« Reply #23 on: February 18, 2013, 02:56:42 PM »
Did this project get shelved for the e power job?
Offline RC Storick
« Reply #24 on: February 19, 2013, 09:15:56 AM »
Its on hold till my NATS plane is done. I was just building it to fill time. Ill get roundtoit.
