  • July 12, 2025, 07:47:53 PM
Author Topic: Lost Foam Jig: my first time  (Read 40976 times)
Re: Lost Foam Jig: my first time
« Reply #100 on: March 28, 2013, 06:11:29 PM »
Fishing the leadout... 8)Marcus
Marcus,
Gotcha!
I thought it was for a bad Vaudeville Act.   n~
You ARE moving along at a good pace.
Charles
Offline MarcusCordeiro
« Reply #101 on: March 29, 2013, 05:17:55 AM »
Thanks Charles.
Not as fast as I wanted, but it's good to see it coming together.
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
« Reply #102 on: April 10, 2013, 04:02:39 PM »
After some advice from more experienced people, I dropped the clamping and moved on to the regular bolt system.
I have to say it does look "better"...
Marcus
Aces High!
« Reply #103 on: April 10, 2013, 05:17:17 PM »
Marcus
Marcus,
What "Clamping?"
Charles
« Reply #104 on: April 10, 2013, 05:38:38 PM »
Marcus
Aces High!
« Reply #105 on: April 10, 2013, 05:57:02 PM »
Marcus,
I've never seen an installation like that, "clamping."
Good choice.
Charles
« Reply #106 on: April 18, 2013, 03:47:05 PM »
I'll do my best to have this wing finished by yhe end of the weekend.
Marcus
Aces High!
« Reply #107 on: April 19, 2013, 08:14:06 PM »
A little more progress...
Marcus
Aces High!
« Reply #108 on: April 22, 2013, 03:51:18 PM »
I got some tips for my "tips" and thought I could use some of it...
I added a soft balsa block and rough sanded to shape.
I still have some work to do on those tips, but I guess the final result will be worth the work.
Marcus
Aces High!
Offline ash
« Reply #109 on: April 22, 2013, 05:18:13 PM »
I like the way you've done the tips, with no straight rib at the end.
« Reply #110 on: April 22, 2013, 06:42:18 PM »
Thanks Ash...
Marcus
Aces High!
« Reply #111 on: April 23, 2013, 06:41:23 AM »
Hi Bob
Thanks for the "tips" for the tips... ;)
Actually, I borrowed that idea from David F., as I have always used the traditional metal horn retainer, and when I was going to install the horn, I figured I was out... LL~
That is fiberglass+epoxi.
Those look way cool!!
That's why I love this forum. I have learned so much good stuff here...
And you may suggest everuthing you think would help me build it better, anytime you like!!!
Gee, when I come to America, I'm going to have to buy lunch for a lot of people... H^^ H^^ H^^
Marcus
Marcus
Aces High!
« Reply #112 on: April 30, 2013, 05:31:26 PM »
I was trying to decide between take apart or not...
I'll do it take apart, so I had to plan how I was going to build it since this is my first take apart ship.
Now that I've positioned the wing correctly it's gonna go fast.
I should have everything well advanced by the time I get my foam stab/elev...
And gotta buy a long 7/64 hex wrench or something, it is really hard to reach the hex bolts inside the tank compartment...
Marcus
Aces High!
« Reply #113 on: April 30, 2013, 07:14:37 PM »
Marcus,
"Take-apart" to get on an airplane with?
Curious?
How precision is that incidence meter?
Charles
« Reply #114 on: April 30, 2013, 07:19:42 PM »
Well, I borrowed it and to be very honest, i didn't like it very much...
The digital display shows one number then you try it again, it shows another number, like a small variation of 00.1 or 00.2...
When i buy mine, it'll be the one from Robartm which is more "I like it old-school" thing...
But it's better then nothing and there's always the barnyard engineering eyeballing method... LL~ LL~ LL~ LL~ LL~
Marcus
Aces High!
« Reply #115 on: April 30, 2013, 07:42:10 PM »
Marcus
Marcus,
Throw it away. There are better ways than using that and better ways than eye-balling.
What about that bloody take-apart! You going on a Holiday?
Charles
« Reply #116 on: May 09, 2013, 07:31:38 PM »
Been working on the wing saddle and have to do some sanding and stuff, but it's coming out OK.
Have removed the wing a few times and no problems, so I'm glad about it, as I see it, the first time you remove the wing and put it back is the ultimate test to check if one has done a good job. Next one is going to have the two separate panels, which seems to be the best option if you plan to travel and bring the ship along.
And I've got lucky! A friend has a Bob Hunt's masterflight set of stab/elev for the TG and is no longer going to use it, so in a couple of days, I'll have it here...
That is gonna save me a lot of time. A little luck sometimes doesn"t hurt, does it?
Marcus
Aces High!
« Reply #117 on: May 16, 2013, 03:59:59 PM »
The wing building is over, though have to work on the flaps yet.
And I made sure the weight box is on the bottom...
Marcus
Aces High!
« Reply #118 on: May 22, 2013, 04:21:59 AM »
I've done some work on the fuselage top.
Now I have to mold the fuselage top.Pics soon...
Marcus
Aces High!
« Reply #119 on: May 24, 2013, 08:22:20 PM »
A little more done...
Used first 1/32 then 1/16 and layered the fuse top, molding didn't work... HB~>
It's nice to see it shaping up...
Marcus
Aces High!
« Reply #120 on: May 24, 2013, 08:58:05 PM »
Why didn't it work?
« Reply #121 on: May 24, 2013, 10:00:20 PM »
The balsa didn't curve. I used the top bulkheads to try to mold the wood. Not good enough.
You have to have a real mold to get a good piece...
After reading Jose's thread my concept abojt building a fuselage has changed...
Marcus
Aces High!
Offline RC Storick
« Reply #122 on: May 26, 2013, 05:36:17 PM »
You have to soak the wood in hot water and then mold. It takes A grain soft wood to do so.
« Last Edit: May 27, 2013, 08:18:10 AM by Robert Storick »
Online FLOYD CARTER
« Reply #123 on: May 26, 2013, 06:07:33 PM »
I'd like to know how anyone can mold "C" grain balsa.  I go for "A" grain, usually 1/32 and two layers with silkspan between.
« Reply #124 on: May 27, 2013, 07:27:30 AM »
I did it Robert, and the balsa was soft enough. The problem is the way I molded it, so I didn't get a good part.
Next one I'll do it the proper way.
Marcus
Aces High!
Offline RC Storick
« Reply #125 on: May 27, 2013, 08:18:43 AM »
OOPS
« Reply #126 on: June 01, 2013, 09:39:09 PM »
I just got the foam stab/elev... And CF LG...
Now let me finish this ship...
Marcus
Aces High!
« Reply #127 on: June 02, 2013, 12:26:26 PM »
Marcus
Marcus,
You through for CF landing gear!! Oh my gosh, that stuff is costly.
Looks really good though.
Any other plans for CF? Prop, spinner.
Nice but way out of my league.
Charles
« Reply #128 on: June 03, 2013, 10:54:02 PM »
Unidirectional CF isn't that expensive, and it's fine for LG's and all you need for props. Not a bad idea to put a layer of light fiberglass in the middle of a LG and on the tips of props, to prevent splitting. You can get some from Tower Hobby...look under Dave Brown Products. $6 worth should make a LG. If you need more, I'd go to CST.  :o Steve
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXB964&P=ML
Offline Balsa Butcher
  • High Desert Flier
« Reply #129 on: June 04, 2013, 12:36:18 PM »
Funny you should mention that Steve. I'm repairing the LG on the Olympian with some unidirectional CF. It has a crack in the middle which may be the result of loose mounting screws and the 15 or so touchdowns I made on that last official in the wind at the NW regionals.  b1  8) BTW: Good info on this thread, Thanks.
« Last Edit: June 04, 2013, 04:34:01 PM by Balsa Butcher »
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #130 on: June 04, 2013, 07:37:02 PM »
It took me a while, but I've gotthe stab/elev, and they are more advanced than I thought.
Already sheeted and LE and TE installed too.
Now, let me get back to work...
Marcus
Aces High!
« Reply #131 on: June 06, 2013, 07:29:50 AM »
I got the stab almost finished, so all I've had to do was the mount...
Have to shape it a little better and stuff, but the holes are ready.
Marcus
Aces High!
Offline Matt Colan
« Reply #132 on: June 06, 2013, 07:38:34 AM »
It's looking really good Marcus! Your plugging away at yours way faster than mine when that was going together.
« Reply #133 on: June 06, 2013, 07:45:09 AM »
Thanks Matt
Gotta get this in the air!
Got my ass kicked last contest by a piped ship... LL~ LL~
And I have to thanks Mr. David Fitzgerald and Mr. Bob Hunt for their help.
You guys are my "heroes"!!
Marcus
Aces High!
« Reply #134 on: June 07, 2013, 07:30:03 AM »
Thanks Matt
Marcus
Marcus!!
Are they "The Wind Beneath Your Wings?"   LL~ LL~ LL~
I'm just kidding!! Really just kidding!!
Cuz I know you have a sinse of humor. Right?  n~
Hey Marcus!
Is that a Photoshop photo or are you realy 5' off the ground inverted? Kudos! I'm still nervous at ten ft.   %^
Charles
« Reply #135 on: June 07, 2013, 03:31:43 PM »
The stab saddle is done.
Now gonna work on the removable fuselage/rudder piece.
Already know how I'll hold it in place.
One more step ahead... 8)
Thanks Charles for posting the pic...
Marcus
Aces High!
« Reply #136 on: June 08, 2013, 03:56:58 PM »
What you see in the pics above...
Marcus
Aces High!
« Reply #137 on: June 08, 2013, 04:42:16 PM »
Good Luck with the new ship, Marcus!  It won't be long before the sanding begins!
BIG Bear
RNMM/AMM
« Reply #138 on: June 11, 2013, 07:34:06 AM »
Thanks Bill.
Been working on a few reinforcements for the take-apart wing, should finish later today.
There's still some work ahead, bur it's coming out good.
My main concern is adding too much weight, since this ship is intended for contests, so  n~ n~
It seems it's going to be a little nose heavy, but let's wait and see.
Now, should I go for monokoted wings and painted fuse/tail??
It ought to speed up finishing a little, and save some weight, I guess...
Marcus
Aces High!
« Reply #139 on: June 11, 2013, 08:49:57 AM »
Depends on how much finish you put on it.   I have seen some come out lighter and mucho better looking than the iron ons.  Also may help your nose heaviness.
« Reply #140 on: June 11, 2013, 11:37:13 AM »
I've Always heard if you build'em tail-heavy, not good.
My old man used to say 1 gram at the tail equals 10 at the nose...
Don't know if all this hocus pocus is true, I'm trying to get the lightest ship possible and truth is, I've Always f#@* up at the finishing, adding too much stuff in the search for a great look...
I might consider the concept "Rat Rod" for this ship, like no painting, only details and clear....
<My friend Marlus has offered to teach me some basic concepts, so I can go on from there, but I know he's very, very busy, and don't want to bother him.
The idea is that practice makes perfection, so I have saved 2 models to paint before I actually paint this one, they'll give me some practice and if I screw up, I'll do with one of those, my son's ARF Nobler and one ARF Pathfinder, the covering simply came off...
I see Derek, Robert, and the others do it and get amped up to do so too.
Soon I'll be moving this thread to finishing and then, well, then is then... :-\ :-\ :-\
Marcus
Aces High!
« Reply #141 on: June 11, 2013, 02:49:11 PM »
Just a couple pics of the fuselage - wing saddle... needs a few touch ups but almost done for good...
Marcus
Aces High!
« Reply #142 on: June 11, 2013, 06:37:00 PM »
Marcus,
Great so far!
This take apart. For traveling by air? Or because of a small car. Or, easy to ship to me.  ;D
Gotta be one of those three.
Charles
« Reply #143 on: June 26, 2013, 09:03:20 PM »
That tailpiece... Does it look like I tore it in two pieces while getting it off, 'cause the guide pin jammed??
 SH^ SH^ SH^
Marcus
Aces High!
« Reply #144 on: June 27, 2013, 08:15:21 PM »
That tail is taking shape...
I think I'll take saturday off to build only, no flying.
Marcus
Aces High!
« Reply #145 on: July 03, 2013, 06:59:48 PM »
Following Bob Hunt's Horn Installation Manual...
Cool and easy!
Marcus
Aces High!
« Reply #146 on: July 03, 2013, 07:35:27 PM »
Marcus!
You Rogue you.  ;D
Looking really good! Kudos!!
 Hard to believe there's foam in there.
Hey! Please run this by me one more time. Exactly why are you building this "take apart" model?
Charles
« Reply #147 on: July 04, 2013, 06:50:40 AM »
Charles
Planning ahead is the key to success.
When I decided on the Thundergazer for contests, I knew i had much to learn, as a builder and as a pilot.
Been practicing hard, and it's been paying off, as I've gotten very good results in contests this year.
So going to contests means traveling and that means spending cash, that is cheaper when more people share the trip.
Putting F2b models and people in compact cars is hard, so everybody has a take-apart here.
But, It also makes it possible to finish this one, and then build a new fuselage, for the eflite 32 I have here, and then being able to fly eletric, without having to build a whole new Bird.
I can also experimente with different stab/elev, like foam, build up or foam/build up and learn from it.
To be very honest, I'm really impressed with Jose's moulded fuselages and might try it too, so it's like having a few chassis and engines and finding the right set up.
I've learned so much in this fórum, and am grateful for it, but the most importante thing I've learned is that we never really actually stop learning.
And there's Always so much to learn...
Marcus
Aces High!
« Reply #148 on: July 05, 2013, 12:43:09 PM »
Almost finished there...
Marcus
Aces High!
« Reply #149 on: July 05, 2013, 08:14:59 PM »
Marcus,
Shaping up!!
Looks like we do our hinges a bit differently?
I may be wrong, and correct me if I am. I see you knoch out the LE of the elevator and not that of the TE of the stab. Correct?
I set mine in 50 50. Half the hinge into the TE and half in the LE.
That's how I was shown. Been doing it that way for over 25 years.
Will you be glassing?
Charles
