  • June 18, 2025, 03:01:36 PM
Author Topic: Leadout guide eyelet material  (Read 1496 times)
« on: February 21, 2013, 05:02:34 AM »
Guys,
I am getting ready to makeup the leadout ends on my El Diablo and have the eyelet type adjustable line positioner. A friend gave me some nylon eyelets which I have never used before. Doing a search on this board one comment indicated that brass eyelets would last over 2000 flights. I am leaving the leadouts long enough to allow clipping and redoing the eyelets but was wondering if anyone has used nylon or other eyelet material and what seems the better choice?
Best,        DennisT
Re: Leadout guide eyelet material
« Reply #1 on: February 21, 2013, 06:10:56 AM »
One good material is the spray tube from a WD-40 can.
« Reply #2 on: February 21, 2013, 09:32:54 AM »
One of the top guys uses nylon 4-40 screws with holes drilled through the middle.  I can't remember who.  They stay in better than relying on a friction fit.
Offline Jim Thomerson
« Reply #3 on: February 21, 2013, 10:10:20 AM »
I use the yellow inside tubing from the golden rod type control rods.  So far as I can see, it will last indefinately and will not wear the leadouts. It is the same stuff that comes in the Perfect leadout packages.
  • Gravitywell
« Reply #4 on: February 21, 2013, 12:07:58 PM »
Doug Moon in his thread "Building Another One" has a couple of pictures of this with a description of how it works.  Its on page two around the middle of the page.   H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline John Cralley
« Reply #5 on: February 21, 2013, 12:29:27 PM »
I use aluminum Pop rivets for eyelets. You just drive the pin out of the rivet and ream the end out. Leadout wire is harder than aluminum so should not cause a wear problem (for the leadout wire but could I suppose, eventually wear the eyelets).
John Cralley
AMA 52183
Central Illinois
« Reply #6 on: February 22, 2013, 08:32:18 AM »
I have been using pop rivet material ever since I saw the post on SSW about building wingtips and adjustable leadouts.  So far so good.
Tags: leadout  eyelet  nylon
